New N54 All Aluminum Water Pump
1,620
Be sure to check the hose coupler at the block near the OFH. That is the plastic fitting that cracks or blows apart.
Also when replacing with the aluminum part, make sure to use a new o-ring and that it goes in straight and doesn’t get pinched. That’ll leak for sure. (Ask me how I know - doh!)
Reactions: NoQuarter
3,595
I always recommend a bit of lubricant on any o-ring, just a bit on two fingers and run over the whole o-ring. I use white lithium grease.
Msoden82
19
10
Sorry to revive a dead thread. Dealing with coolant boiling through the res cap so suspecting a water pump is in my future.
How’s the Piersburg aluminum one treating those who have it?
rac
341
204
135i ST
Is this the one from a while back that ppl said flowed less ? Or different one ?
there are like for like replacements now with aluminum casing and same power motor. i have one also.
the one your thinking about is probably the n52.
