N55 Codes List
I finally managed to convert that huge list of codes into a text format. There may be errors from the conversion, please reference the attached PDF to be sure and let me know if you find any mistakes.
To view all the columns, you'll need to download the PDF as not all have been included due to formatting purposes.
Fault Code (hex)Fault Code (dez)BMW Fault Code Description VS-TextFault descriptionDTC (Diagnostic Trouble Code)DTC Description
0x271010000Throttle valve, function: jammed permanentlyThe diagnostic function checks the throttle valve's control signal for excessively high figures that would indicate that the throttle valve
is seizing.
P1639Throttle Valve Position Control Throttle Stuck Permanently (Bank 1)
0x271110001Throttle valve, function: jammed brieflyThe diagnostic function monitors the throttle valve control signal for excessively high figures
that would indicate that the throttle valve is sticking or seizing.
P1638Throttle Valve Position Control Throttle Stuck Temporarily (Bank 1)
0x271410004Throttle valve, function: sluggish, too slowThe diagnostic function monitors the difference between specified and actual throttle-valve values. If this figure remains too high for a specified period, a fault is recognized and the throttle valve is deactivated.P11AAThrottle tight (Bank 1)
0x277410100Mass air flow sensor, plausibility: Air mass compared with model too highThe diagnostic function compares the calculated air mass with the measured air mass.P00BDMass or Volume Air Flow 'A' Circuit Range/Performance - Air Flow Too High
0x277410100Mass air flow sensor, plausibility: Air mass compared with model too highThe diagnostic function compares the calculated air mass with the measured air mass.P115DMass or Volume Air Flow 'A' Air Mass Too High Compared to Model
0x277510101Mass air flow sensor, plausibility: Air mass compared with model too lowThe diagnostic function compares the air mass calculated from the model with the measured air
mass.
P00BCMass or Volume Air Flow 'A' Circuit Range/Performance - Air Flow Too Low
mass.
P115CMass or Volume Air Flow 'A' Air Mass Too Low Compared to Model
0x277810104Air mass sensor, signal: Implausible period duration, loose contact with low frequencyThe diagnostic function monitors the upper limit of the digital HFM signal's period duration.P0103Mass or Volume Air Flow Sensor 'A' Circuit High
0x277910105Air mass sensor, signal: Implausible period duration, loose contact with high frequencyThe diagnostic function monitors the lower limit of the digital HFM signal's period duration.P0102Mass or Volume Air Flow Sensor 'A' Circuit Low
0x277A10106Air mass sensor, signal: Short-circuit or line break (open circuit)The diagnostic function determines whether a digital signal from the HFM is present.P0100Mass or Volume Air Flow Sensor 'A' Circuit
0x277B10107P00BDMass or Volume Air Flow 'A' Circuit Range/Performance - Air Flow Too High
0x277B10107P0103Mass or Volume Air Flow Sensor 'A' Circuit High
0x277C10108P00BCMass or Volume Air Flow 'A' Circuit Range/Performance - Air Flow Too Low
0x277C10108P0102Mass or Volume Air Flow Sensor 'A' Circuit Low
0x27D910201Accelerator pedal module, pedal sensor 1, electrical: Short circuit to B+The diagnostic function monitors the voltage of sensor 1.P2123Throttle/Pedal Position Sensor/Switch 'D' Circuit High
0x27DA10202Accelerator pedal module, pedal sensor 1, electrical: Short circuit to earth or line disconnectionThe diagnostic function monitors the voltage of sensor 1.P2122Throttle/Pedal Position Sensor/Switch 'D' Circuit Low
0x27DB10203Pedal module, pedal sensor 2, electrical: Short circuit to B+The diagnostic function monitors the voltage of sensor 2.P2128Throttle/Pedal Position Sensor/Switch 'E' Circuit High
0x27DC10204Pedal module, pedal sensor 2, electrical: Short circuit to earth or line disconnectionThe diagnostic function monitors the voltage of sensor 2.P2127Throttle/Pedal Position Sensor/Switch 'E' Circuit Low
0x27E410212Accelerator-pedal module, pedal-travel sensor Multiple faultCollective fault: Accelerator pedal module's pedal-travel sensor.
0x27E810216Accelerator pedal module, pedal position sensor, plausibility: synchronisation error between signal
1 and Signal 2
The diagnostic function monitors the mutual deviation between the two sensor voltages.P2138Throttle/Pedal Position Sensor/Switch 'D' / 'E' Voltage Correlation
0x280E10254Absolute pressure sensor, intake manifold, plausibility: Intake-manifold pressure too highDuring the shutdown phase the diagnosis function monitors the DME to determine whether the ambient-air, intake-manifold and boost- pressure sensors are measuring the same
pressure.
P1250Manifold Absolute Pressure Too High
pressure.
P12A5Manifold Absolute Pressure Sensor 'A' Afterrunning Diagnosis Pressure Too High
0x280F10255Absolute pressure sensor, intake manifold, plausibility: Intake-manifold pressure too lowThe diagnostic function monitors the DME's barometric pressure sensor.P1255Manifold Absolute Pressure Too Low
0x280F10255Absolute pressure sensor, intake manifold, plausibility: Intake-manifold pressure too lowThe diagnostic function monitors the DME's barometric pressure sensor.P12A4Manifold Absolute Pressure Sensor 'A' Afterrunning Diagnosis Pressure Too Low
0x281A10266Absolute pressure sensor, intake pipe, electrical: Short circuit to B+The diagnostic function monitors the intake- manifold pressure sensor's upper voltage limit.P0108Manifold Absolute Pressure/Barometric Pressure Sensor Circuit High
0x281A10266Absolute pressure sensor, intake pipe, electrical: Short circuit to B+The diagnostic function monitors the intake- manifold pressure sensor's upper voltage limit.P119AManifold Absolute Presssure Sensor Circuit High (Bank 1)
0x281B10267Absolute pressure sensor, intake pipe, electrical: Short circuit to earthThe diagnostic function monitors the intake- manifold pressure sensor's lower voltage limit.P0107Manifold Absolute Pressure/Barometric Pressure Sensor Circuit Low
0x281B10267Absolute pressure sensor, intake pipe, electrical: Short circuit to earthThe diagnostic function monitors the intake- manifold pressure sensor's lower voltage limit.P119BManifold Absolute Presssure Sensor Circuit Low (Bank 1)
0x283C10300Ambient pressure sensor, electrical: Short to B+ or open circuitThe diagnostic function monitors the DME's barometric pressure sensor.P2229Barometric Pressure Sensor 'A' Circuit High
0x283D10301Ambient pressure sensor, electrical: Short circuit to earthThe diagnostic function monitors the DME's barometric pressure sensor.P2228Barometric Pressure Sensor 'A' Circuit Low
0x284110305Ambient pressure sensor, overrun: Pressure too highDuring the control module's shutdown phase the diagnostic function monitors the barometric- pressure sensor, intake-manifold pressure sensor and boost-pressure sensor to determine whether they are all measuring the same
pressure.
P12B9Ambient Pressure Sensor Afterrunning Diagnosis Pressure Too High
0x284210306Ambient pressure sensor, overrun: Pressure too lowThe diagnostic function monitors the voltage at the boost pressure sensor.P12B8Ambient Pressure Sensor Afterrunning Diagnosis Pressure Too Low
0x284C10316Ambient pressure sensor, plausibility: Pressure too highThe diagnostic function monitors the barometric- pressure sensor.P11CBBarometric Pressure Too High
0x284D10317Ambient pressure sensor, plausibility: Pressure too lowThe diagnostic function monitors the barometric- pressure sensor.P0129Barometric Pressure Too Low
0x284E10318Ambient pressure sensor, plausibility: Pressure implausibleThe diagnostic function monitors the plausibility of the barometric pressure relative to that measured in the previous driving cycle.P1247Barometric Pressure Plausibility
0x284F10319Ambient pressure sensor, plausibility: Pressure implausibleThe diagnostic function monitors variations in the barometric pressure reading for plausibility.P1247Barometric Pressure Plausibility
0x28A010400Throttle-valve angle - intake-manifold pressure, correlation: Limit value exceededThe diagnostic function monitors the throttle valve aperture and the current intake manifold pressure reading to determine whether they are mutually plausible.P112FManifold Absolute Pressure to Throttle Angle - Too High (Bank 1)
0x28A110401Throttle-valve angle - intake-manifold pressure, correlation: Limit value not exceededThe diagnostic function monitors the throttle valve aperture and the current intake manifold pressure reading to determine whether they are mutually plausible.P112EManifold Absolute Pressure to Throttle Angle - Too Low (Bank 1)
0x28A410404Throttle valve, throttle valve potentiometer 1, electrical: Short to B+ or open circuitThe diagnostic function checks the signal from throttle valve actuator 1 for electrical faults.P0123Throttle/Pedal Position Sensor/Switch 'A' Circuit High
0x28A510405Throttle valve, throttle valve potentiometer 1, electrical: Short circuit to earthThe diagnostic function checks the signal from throttle valve actuator 1 for electrical faults.P0122Throttle/Pedal Position Sensor/Switch 'A' Circuit Low
0x28A810408Throttle valve, throttle potentiometer 2, electrical: Short circuit to B+The diagnostic function checks the voltage of throttle valve sensor 2 for electrical faults.P0223Throttle/Pedal Position Sensor/Switch 'B' Circuit High
0x28A910409Throttle valve, throttle potentiometer 2, electrical: Short circuit to earth or line
disconnection
The diagnostic function checks the voltage of throttle valve sensor 2 for electrical faults.P0222Throttle/Pedal Position Sensor/Switch 'B' Circuit Low
0x28B010416Throttle valve: Limp-home operating mode activeP169FThrottle Valve Limp Home Mode Active
0x28B410420Throttle valve, throttle potentiometer: plausibility Timing fault between potentiometer 1 and
potentiometer 2
The diagnostic function monitors the mutual deviation between the two sensor voltages.P115FThrottle/Pedal Position Sensor/Switch 'A' / 'B' Synchronous Operation Correlation (Bank 1)
0x28B810424DME, internal fault, activation of throttle valve: Short circuitThe diagnostic function monitors the driver circuit controlling operation of the throttle valve.P2103Throttle Actuator 'A' Control Motor Circuit High
0x28B910425DME, internal fault, activation of throttle valve: Excess temperature or current too highThe diagnostic function monitors the driver circuit controlling operation of the throttle valve.P2118Throttle Actuator 'A' Control Motor Current Range/Performance
0x28BA10426DME, internal fault, activation of throttle valve: Internal communication faultThe diagnostic function monitors the driver circuit controlling operation of the throttle valve.P061FInternal Control Module Throttle Actuator Controller Performance
0x28BB10427DME, internal fault, activation of throttle valve: Line disconnectionThe diagnostic function monitors the driver circuit controlling operation of the throttle valve.P2100Throttle Actuator 'A' Control Motor Circuit/Open
0x28BC10428Throttle valve actuator, closing spring test: Cancellation of check, spring does not closeDuring the spring test the diagnostic function monitors the throttle valve to determine whether it returns to the emergency air position within the specified period when no voltage is being
applied.
P1634Throttle Valve Adaptation Spring Test Failed (Bank 1)
0x28BD10429Throttle valve actuator, closing spring test: Fault during spring checkDuring the spring test the diagnostic function monitors the throttle valve to determine whether it reaches the specified position within the
specified period.
P1631Throttle Valve Actuator Spring Test (Bank 1)
0x28C010432Throttle valve actuator, opening spring test: Cancellation of check, spring does not openDuring the spring test the diagnostic function monitors the throttle valve to determine whether it returns to the emergency-air position within the specified period when no voltage is being
applied.
P1629Throttle Valve Actuator Spring Test Stop, Spring does not Open (Bank 1)
0x28C110433Throttle valve actuator, opening spring test: Fault during spring checkDuring the spring test the diagnostic function monitors the throttle valve to determine whether it reaches the specified position below the emergency-air point within the specified time.P1628Throttle Valve Actuator Spring Test Malfunction during Opening (Bank 1)
0x28C410436Throttle valve, adaptation: emergency running position not adaptedThe diagnostic function monitors the throttle valve to determine whether it is at the emergency air position (open at angle of roughly
7.6°) when no voltage is applied.
P1633Throttle Valve Adaptation Limp-Home Position Unknown (Bank 1)
0x28CC10444Throttle valve, adaptation: Marginal conditions not metDuring the throttle valve adaptation the diagnostic function monitors compliance with the prescribed process conditions.P1632Throttle Valve Adaptation Conditions Not Met (Bank 1)
0x28CD10445Throttle valve, adaptation: Marginal conditions not met; battery voltage too lowThe diagnostic function monitors the throttle valve to determine whether it reaches the lower mechanical travel stop (UMA) during the initial
adaptation.
P16E6Throttle Valve Adaptation Conditions Not Met, Battery Voltage Too Low (Bank 1)
0x28D010448Throttle valve, adaptation: Initial adaptation, lower limit position not taught inThe diagnostic function monitors the throttle valve to determine whether it reaches the lower mechanical travel stop (UMA) during a repeat throttle-valve adaptation routine (after roughly 30 sec. Terminal 15 without engine start).P16BCThrottle Valve Adaptation Lower Stop Not Learned (Bank 1)
0x28D410452Throttle valve, adaptation: Teach in again, lower limit position not taught inDuring the throttle valve adaptation routine the diagnostic function monitors the offset and amplification of throttle valve potentiometer 1 in
the amplified range.
P1644Throttle Valve Adaptation Stop Relearning Lower Mechanical Stop (Bank 1)
0x290610502Intake air system: Suspicion of leaks between turbocharger and intake valvesThe diagnostic function monitors the compressed intake air.
Coolant temperature sensor, electrical: ShortThe diagnostic function monitors the coolantEngine Coolant Temperature Sensor 1 Circuit Low
  • BMW N55 Diagnostic Fault Codes.pdf
I've got a TON of work in front of me, but I will get this into text/spreadsheet form.
Reactions: 343cab
0x293710551Coolant temperature sensor, electrical: Short to B+ or open circuitThe diagnostic function monitors the coolant temperature sensor's wires.P0118Engine Coolant Temperature Sensor 1 Circuit High
0x293A10554Coolant temperature sensor, cold start: Coolant temperature too highThe diagnostic function monitors the coolant temperature to detect excessively high values
during cold starts.
P10D5Cold Start Engine Coolant Temperature Too Low
0x293B10555Coolant temperature sensor, cold start: Coolant temperature too lowThe diagnostic function monitors the coolant temperature to detect excessively low values
during cold starts.
P10D4Cold Start Engine Coolant Temperature Too Low
0x294310563Coolant temperature sensor, plausibility: Signal change too fastThe diagnostic function monitors the coolant temperature sensor's voltage signal for
plausibility.
P0116Engine Coolant Temperature Sensor 1 Circuit Range/Performance
plausibility.
P3198Engine Coolant Temperature 1 Gradient Too High
0x294710567Coolant temperature sensor, plausibility: Engine temperature compared with model implausibly
too low
The diagnostic function monitors the coolant temperature sensor.P112BEngine Coolant Temperature Too Low
too low
The diagnostic function monitors the coolant temperature sensor.P316BEngine Coolant Temperature Signal Stuck Low
0x294810568Coolant temperature sensor, plausibility: Engine temperature implausibleThe diagnostic function monitors the coolant temperature sensor.P0116Engine Coolant Temperature Sensor 1 Circuit Range/Performance
0x294810568Coolant temperature sensor, plausibility: Engine temperature implausibleThe diagnostic function monitors the coolant temperature sensor.P3199Engine Coolant Temperature Signal Stuck
0x299A10650Outside temperature sensor, signal: Upper threshold value exceededThe diagnostic function monitors the outside temperature sensor for excessively high temperature figures.P0073Ambient Air Temperature Sensor Circuit 'A' High
0x299B10651Outside temperature sensor, signal: Lower threshold value undershotThe diagnostic function monitors the outside temperature sensor for excessively low temperature figures.P0072Ambient Air Temperature Sensor Circuit 'A' Low
0x299C10652Outside temperature sensor, signal: CAN message faultyThe diagnostic function monitors the outside temperature sensor's CAN data.P110FAmbient Air Temperature Sensor Faulty CAN Signal
0x29A210658Outside temperature sensor, plausibility:
Ambient temperature higher than model temperature
The diagnostic function checks the plausibility of the outside temperature.P0071Ambient Air Temperature Sensor Circuit 'A' Range/Performance
The diagnostic function checks the plausibility of the outside temperature.P10EAAmbient Air Temperature Too High
0x29A310659Outside temperature sensor, plausibility:
Ambient temperature less than model temperature
The diagnostic function checks the plausibility of the outside temperature.P10EBAmbient Air Temperature Too Low
0x29CC10700Intake air temperature sensor, cold start: Intake- air temperature too highThe diagnostic function monitors the intake-air temperature to detect excessively high values
during cold starts.
P10C9Cold Start Intake Air Temperature Too High (Bank 1)
0x29CD10701Intake air temperature sensor, cold start: Intake- air temperature too lowThe diagnostic function monitors the intake-air temperature to detect excessively low values
during cold starts.
P105DCold Start Intake Air Temperature Too Low (Bank 1)
0x29D010704Intake air temperature sensor, electrical: Short circuit to B+The diagnostic function monitors the upper voltage limit of the intake-air temperature sensor on the engine-side of the air filter.P0113Intake Air Temperature Sensor 1 Circuit High (Bank 1)
0x29D110705Intake air temperature sensor, electrical: Short circuit to earthThe diagnostic function monitors the lower voltage limit of the intake-air temperature sensor on the engine-side of the air filter.P0112Intake Air Temperature Sensor 1 Circuit Low (Bank 1)
0x29D210706Intake air temperature sensor, electrical: Signal not plausibleThe diagnostic function monitors the voltage of the intake-air temperature sensor on the engine- side of the air filter to detect jumps that violate
the specified level.
P0111Intake Air Temperature Sensor 1 Circuit Range/Performance (Bank 1)
0x29D810712Intake air temperature sensor, plausibility: Intake-air temperature too highThe diagnostic function monitors the intake-air temperature to detect implausibly high figures.P0127Intake Air Temperature Too High
0x29D910713Intake air temperature sensor, plausibility: Intake-air temperature too lowThe diagnostic function monitors the intake-air temperature to detect implausibly low figures.P11C9Intake Air Temperature Too Low
0x29DC10716Charge-air temperature sensor, cold start: Charge air temperature too highThe diagnostic function monitors the charge-air temperature to detect excessively high values
during cold starts.
P10D0Cold Start Charge Air Temperature Too High (Bank 1)
0x29DD10717Charge-air temperature sensor, cold start: Charge-air temperature too lowThe diagnostic function monitors the charge-air temperature to detect excessively low values
during cold starts.
P10D1Cold Start Charge Air Temperature Too Low
0x29E010720Charge-air temperature sensor, electrical : Short circuit to B+The diagnostic function monitors the upper voltage limit of the intake-air temperature sensor on the engine-side of the air filter.P007DCharge Air Cooler Temperature Sensor Circuit High (Bank 1)
0x29E110721Charge-air temperature sensor, electrical : Short circuit to earthThe diagnostic function monitors the lower voltage limit of the intake-air temperature sensor on the engine-side of the air filter.P007CCharge Air Cooler Temperature Sensor Circuit Low (Bank 1)
0x29E210722Charge-air temperature sensor, electrical : Signal not plausibleThe diagnostic function monitors the voltage of the intake-air temperature sensor on the engine- side of the air filter to detect jumps that violate
P007BCharge Air Cooler Temperature Sensor Circuit Range/Performance (Bank 1)
0x29E410724Charge-air temperature sensor, plausibility: Charge air temperature too highThe diagnostic function monitors the charge-air temperature to detect implausibly high figures.P10B0Charge Air Cooler Temperature Too High (Bank 1)
0x29E510725Charge-air temperature sensor, plausibility: Signal frozenThe diagnostic function monitors the charge-air temperature sensor for an invariable signal.P10B8Charge Air Cooler Temperature Sensor Signal Stuck (Bank 1)
0x29E810728Charge-air temperature sensor, gradient: Rise too highThe diagnostic function monitors the charge-air temperature for excessively rapid rises.P007BCharge Air Cooler Temperature Sensor Circuit Range/Performance (Bank 1)
0x29E810728Charge-air temperature sensor, gradient: Rise too highThe diagnostic function monitors the charge-air temperature for excessively rapid rises.P10B4Charge Air Cooler Temperature Sensor Gradient Too High (Bank 1)
0x29FE10750Injection system, cylinder 1, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3149Cylinder 1 High Pressure Injector High Side Circuit Low
0x29FF10751Injection system, cylinder 1, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3102Cylinder 1 High Pressure Injector Low Side Circuit High
0x2A0010752Injection system, cylinder 1, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3150Cylinder 1 High Pressure Injector High Side Circuit High
0x2A0110753Injection system, cylinder 1, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3101Cylinder 1 High Pressure Injector Low Side Circuit Low
0x2A0210754Injection system, cylinder 2, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3152Cylinder 2 High Pressure Injector High Side Circuit Low
0x2A0310755Injection system, cylinder 2, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3106Cylinder 2 High Pressure Injector Low Side Circuit High
0x2A0410756Injection system, cylinder 2, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3153Cylinder 2 High Pressure Injector High Side Circuit High
0x2A0510757Injection system, cylinder 2, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3105Cylinder 2 High Pressure Injector Low Side Circuit Low
0x2A0610758Injection system, cylinder 3, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3155Cylinder 3 High Pressure Injector High Side Circuit Low
0x2A0710759Injection system, cylinder 3, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3110Cylinder 3 High Pressure Injector Low Side Circuit High
0x2A0810760Injection system, cylinder 3, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3156Cylinder 3 High Pressure Injector High Side Circuit High
0x2A0910761Injection system, cylinder 3, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3109Cylinder 3 High Pressure Injector Low Side Circuit Low
0x2A0A10762Injection system, cylinder 4, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3158Cylinder 4 High Pressure Injector High Side Circuit Low
0x2A0B10763Injection system, cylinder 4, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3114Cylinder 4 High Pressure Injector Low Side Circuit High
0x2A0C10764Injection system, cylinder 4, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3159Cylinder 4 High Pressure Injector High Side Circuit High
0x2A0D10765Injection system, cylinder 4, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3113Cylinder 4 High Pressure Injector Low Side Circuit Low
0x2A0E10766Injection system, cylinder 5, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3161Cylinder 5 High Pressure Injector High Side Circuit Low
0x2A0F10767Injection system, cylinder 5, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3118Cylinder 5 High Pressure Injector Low Side Circuit High
0x2A1010768Injection system, cylinder 5, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3162Cylinder 5 High Pressure Injector High Side Circuit High
0x2A1110769Injection system, cylinder 5, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3117Cylinder 5 High Pressure Injector Low Side Circuit Low
0x2A1210770Injection system, cylinder 6, activation: High voltage side; short to groundThe diagnostic function monitors control- activation of the injector's high-voltage side.P3164Cylinder 6 High Pressure Injector High Side Circuit Low
0x2A1310771Injection system, cylinder 6, activation: Low voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's low-voltage side.P3122Cylinder 6 High Pressure Injector Low Side Circuit High
0x2A1410772Injection system, cylinder 6, activation: High voltage side; short to positiveThe diagnostic function monitors control- activation of the injector's high-voltage side.P3165Cylinder 6 High Pressure Injector High Side Circuit High
0x2A1510773Injection system, cylinder 6, activation: Low voltage side; short circuit to earthThe diagnostic function monitors control- activation of the injector's low-voltage side.P3121Cylinder 6 High Pressure Injector Low Side Circuit Low
0x2A3010800Injection system, cylinder 1 high voltage side, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3148Cylinder 1 High Pressure Injector High Side Shorted to Coil
0x2A3110801Fuel injector, cylinder 2, high voltage side, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3151Cylinder 2 High Pressure Injector High Side Shorted to Coil
0x2A3210802Fuel injector, cylinder 3, high voltage side, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3154Cylinder 3 High Pressure Injector High Side Shorted to Coil
0x2A3310803Injection system, cylinder 4, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3157Cylinder 4 High Pressure Injector High Side Shorted to Coil
[TBODY] [/TBODY]
0x2A3410804Injection system, cylinder 5, high-voltage side, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3160Cylinder 5 High Pressure Injector High Side Shorted to Coil
0x2A3510805Fuel injector, cylinder 6, high voltage side, activation: Interturn faultThe diagnostic function monitors control- activation of the injector's high-voltage side.P3163Cylinder 6 High Pressure Injector High Side Shorted to Coil
0x2A4010816Fuel injector, cylinder 1 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3103Cylinder 1 High Pressure Injector Low Side Booster Time Error
0x2A4110817Fuel injector, cylinder 2 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3107Cylinder 2 High Pressure Injector Low Side Booster Time Error
0x2A4210818Fuel injector, cylinder 3 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3111Cylinder 3 High Pressure Injector Low Side Booster Time Error
0x2A4310819Fuel injector, cylinder 4 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3115Cylinder 4 High Pressure Injector Low Side Booster Time Error
0x2A4410820Fuel injector, cylinder 5 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3119Cylinder 5 High Pressure Injector Low Side Booster Time Error
0x2A4510821Injection system, cylinder 6 low voltage side, activation: Booster time windowThe diagnostic function monitors control- activation of the injector's low-voltage side.P3123Cylinder 6 High Pressure Injector Low Side Booster Time Error
0x2A4C10828Fuel injector, cylinder 1 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3100Cylinder 1 High Pressure Injector Low Side Circuit Open
0x2A4D10829Fuel injector, cylinder 2 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3104Cylinder 2 High Pressure Injector Low Side Circuit Open
0x2A4E10830Fuel injector, cylinder 3 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3108Cylinder 3 High Pressure Injector Low Side Circuit Open
0x2A4F10831Fuel injector, cylinder 4 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3112Cylinder 4 High Pressure Injector Low Side Circuit Open
0x2A5010832Fuel injector, cylinder 5 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3116Cylinder 5 High Pressure Injector Low Side Circuit Open
0x2A5110833Injection system, cylinder 6 low voltage side, activation: Line disconnectionThe diagnostic function monitors control- activation of the injector's low-voltage side.P3120Cylinder 6 High Pressure Injector Low Side Circuit Open
0x2A5F10847Injection systems, voltage supply: Short circuit to B+The diagnostic function monitors the wire for the injector voltage supply from the overload- protection relay for ignition and injection for short circuits to positive.
0x2A6010848Injection systems, voltage supply: Short circuit to earthThe diagnostic function monitors the wire for the injector voltage supply from the overload- protection relay for ignition and injection for
short circuits to ground.
0x2A6110849Injection systems, voltage supply: Line disconnectionThe diagnostic function monitors the wire for the injector voltage supply from the overload- protection relay for ignition and injection for an
open circuit.
0x2A7010864DME, internal fault, HDEV output stage module 1: SPI communication faultyThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2A7110865DME, internal fault, HDEV output stage module 2: SPI communication faultyThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2A7210866DME, internal fault, HDEV output stage module 1: SPI communication implausibleThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2A7310867DME, internal fault, HDEV output stage module 2: SPI communication implausibleThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2A7410868DME, internal fault, HDEV output stage module 1: SPI communication, signal faultThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2A7510869DME, internal fault, HDEV output stage module 2: SPI communication, signal faultThe diagnostic function monitors the driver circuit responsible for activating the injector.P16A5Control Module Multiple Output Stage SPI-Bus Communication Error
0x2BC011200Mixture adaptation, lower engine speed range: Mixture at partial load too leanThe diagnostic function monitors the mixture adaptation.P0171System Too Lean (Bank 1)
0x2BC011200Mixture adaptation, lower engine speed range: Mixture at partial load too leanThe diagnostic function monitors the mixture adaptation.P2177System Too Lean Off Idle (Bank 1)
0x2BC111201Mixture adaptation, lower engine speed range: Mixture at partial load too richThe diagnostic function monitors the mixture adaptation.P0172System Too Rich (Bank 1)
0x2BC111201Mixture adaptation, lower engine speed range: Mixture at partial load too richThe diagnostic function monitors the mixture adaptation.P2178System Too Rich Off Idle (Bank 1)
0x2BC211202
0x2BC311203
0x2BCA11210Oxygen sensor before catalytic converter Exhaust gas after cat. conv. too richThe diagnostic function monitors the oxygen sensor behind the catalytic converter to determine whether it displays a consistent
deviation.
P2097Post Catalyst Fuel Trim System Too Rich (Bank 1)
0x2BCB11211Oxygen sensor before catalytic converter Exhaust gas after cat. conv. too leanThe diagnostic function monitors the oxygen sensor behind the catalytic converter to determine whether it displays a consistent
deviation.
P2096Post Catalyst Fuel Trim System Too Lean (Bank 1)
0x2BD911225Rail pressure sensor, electrical: Short circuit to B+The diagnosis function monitors the upper voltage limit of the rail-pressure sensor.P0193Fuel Rail Pressure Sensor 'A' Circuit High
0x2BDA11226Rail pressure sensor, electrical: Short circuit to earthThe diagnostic function monitors the rail- pressure sensor's lower voltage limit.P0192Fuel Rail Pressure Sensor 'A' Circuit Low
0x2BDB11227Fuel supply system: Pressure too high, emergency operation with low pressureThe diagnostic function monitors fuel high- pressure system to detect whether it rises above a defined maximum value.P306AFuel Rail/System Pressure - Too High, Limp Home
0x2BDF11231Low pressure fuel system: Power of FP is too high for actual pressureThe diagnostic function monitors the current draw from the electric fuel pump.
0x2BE211234Low pressure fuel system, signal: voltage of electrical fuel pump implausibleThe diagnostic function monitors the voltage at the electric fuel pump.
0x2BE311235Low pressure fuel system, control: Actual pressure too lowThe diagnostic function monitors the fuel low- pressure level's deviation from the specified
value.
0x2BE411236Low pressure fuel system, control: Actual pressure too highThe diagnostic function monitors the fuel low- pressure level's deviation from the specified
value.
0x2BE911241Fuel pressure: Pressure below minimum pressure; injection deactivation for catalytic
converter protection
The diagnostic function monitors the high- pressure system for pressure deviations.P142ECylinder Injection Cut-Off, Pressure Too Low in High-Pressure System
The diagnostic function monitors the high- pressure system for pressure deviations.P306FFuel Rail Pressure, Minimum Pressure Fallen Below, Injection Cut-Off
0x2BEA11242Fuel supply system, oxygen sensor emissions control: upper limit exceededThe diagnostic function monitors the lambda closed-loop mixture control. The mixture is too lean and the lambda control enriches it.P0171System Too Lean (Bank 1)
0x2BEA11242Fuel supply system, oxygen sensor emissions control: upper limit exceededThe diagnostic function monitors the lambda closed-loop mixture control. The mixture is too lean and the lambda control enriches it.P306DFuel Supply Closed Loop Fuel Control, Upper Limit Exceeded
0x2BEB11243Fuel supply system, oxygen sensor emissions control: lower limit undershotThe diagnostic function monitors the lambda closed-loop mixture control. The mixture is too rich and the lambda control dials in a leaner
mixture.
mixture.
P306EFuel Supply Closed Loop Fuel Control, Lower Limit Fallen Below
0x2BEC11244High fuel pressure after engine shutdown: Pressure too highThe diagnostic function monitors the flow-control valve on the high-pressure pump during the
engine's shutdown phase.
0x2BED11245High-pressure fuel system, cold start: Pressure too highThe diagnostic function monitors the high- pressure fuel system to determine whether the pressure levels remain as specified during the
catalyst preheating phase.
P15DECold Start Fuel Pressure Too High (Bank 1)
0x2BEE11246High-pressure fuel system, cold start: Pressure too lowThe diagnostic function monitors pressure levels in the high-pressure fuel system to determine whether they conform to specified levels during the catalyst preheating phase.P15DFCold Start Fuel Pressure Too Low (Bank 1)
0x2BF211250Rail pressure sensor, voltage check: upper threshold exceededThe diagnostic function monitors the voltage of the rail-pressure sensor.P10CEFuel Rail Pressure Sensor 'A' Votage Too High
0x2BF311251Rail pressure sensor, voltage check: lower threshold not reachedThe diagnostic function monitors the voltage of the rail-pressure sensor.P10CFFuel Rail Pressure Sensor 'A' Votage Too Low
0x2BF411252Rail pressure sensor, plausibility: Maximum pressure exceededThe diagnostic function monitors the fuel rail for excessive pressure levels prior to the engine
start.
P0088Fuel Rail/System Pressure - Too High
0x2BF511253Rail pressure sensor, plausibility: Minimum pressure undershotThe diagnostic function monitors the rail pressure to determine whether it drops too low
during engine operation.
P0087Fuel Rail/System Pressure - Too Low
0x2BF611254Fuel low-pressure sensor, electrical: Short circuit to B+The diagnostic function monitors the upper voltage limit of the low-pressure sensor.P2542Low Pressure Fuel System Sensor Circuit High
0x2BF711255Fuel low-pressure sensor, electrical: Short circuit to earthThe diagnostic function monitors the lower voltage limit of the low-pressure sensor.P2541Low Pressure Fuel System Sensor Circuit Low
0x2BF811256Rail pressure sensor, plausibility: Signal frozenThe diagnostic function monitors the variations in the signal from the rail-pressure sensor.P10D9Fuel Rail Pressure Sensor 'A' Signal Stuck
0x2C0011264High pressure fuel system, fuel pressure: Maximum pressure exceededThe diagnostic function monitors the high- pressure fuel system to determine whether the pressure levels remain at the specified levels.P0088Fuel Rail/System Pressure - Too High
0x2C0011264High pressure fuel system, fuel pressure: Maximum pressure exceededThe diagnostic function monitors the high- pressure fuel system to determine whether the pressure levels remain at the specified levels.P302AFuel Rail Pressure, Maximum Pressure Exceeded (Bank 1)
0x2C0111265High pressure fuel system, fuel pressure: Minimum pressure undershotThe diagnostic function monitors the high- pressure fuel system to determine whether the pressure levels remain at the specified levels.P0087Fuel Rail/System Pressure - Too Low
0x2C0111265High pressure fuel system, fuel pressure: Minimum pressure undershotThe diagnostic function monitors the high- pressure fuel system to determine whether the pressure levels remain at the specified levels.P302CFuel Rail Pressure, Minimum Pressure Fallen Below (Bank 1)
0x2C3D11325Quantity control valve, activation: Short circuit to B+The diagnostic function monitors the flow-control valve's control-activation wire for shorts to
positive.
P0004Fuel Volume Regulator Control Circuit High
[TBODY] [/TBODY]
0x2C3E11326Quantity control valve, activation: Short circuit to earthThe diagnostic function monitors the flow-control valve's control-activation wire for shorts to
ground.
P0003Fuel Volume Regulator Control Circuit Low
0x2C3F11327Quantity control valve, activation: Line disconnectionThe diagnostic function monitors the flow-control valve's control-activation wire for an open
circuit.
P0001Fuel Volume Regulator Control Circuit/Open
0x2C5611350Boost pressure control, upper value: Boost pressure too highThe diagnostic function monitors the pressure measured by the boost-pressure sensor.P0234Turbocharger/Supercharger 'A' Overboost Condition
0x2C5711351Charge-air pressure control, lower value: Boost pressure too lowThe diagnostic function monitors the pressure measured by the boost-pressure sensor.P0299Turbocharger/Supercharger 'A' Underboost Condition
0x2C5811352Boost pressure control, deactivation: Boost- pressure build-up blockedThe diagnostic function monitors the DME's deactivation of active boost.P1260Turbocharger/Supercharger Boost Control Cut- Off (Bank 1)
0x2C6F11375Boost pressure sensor, electrical: Short circuit to B+The diagnostic function monitors the wire to the boost-pressure sensor.P0238Turbocharger/Supercharger Boost Sensor 'A' Circuit High
0x2C7011376Boost pressure sensor, electrical: Short circuit to earthThe diagnostic function monitors the wire to the boost-pressure sensor.P0237Turbocharger/Supercharger Boost Sensor 'A' Circuit Low
0x2C7111377Boost pressure sensor. Pressure too highDuring the control module's shutdown phase the diagnostic function monitors the barometric- pressure sensor, intake-manifold pressure sensor and boost-pressure sensor to determine whether they are all measuring the same
pressure.
P12A9Boost Sensor 'A' Afterrunning Diagnosis Pressure Too High
0x2C7211378Boost pressure sensor. Pressure too lowDuring the control module's shutdown phase the diagnostic function monitors the barometric pressure sensor, intake-manifold sensor and the pressure sensor on the air-intake side of the throttle valve to determine whether they are all measuring the same pressure.P12A8Boost Sensor 'A' Afterrunning Diagnosis Pressure Too Low
0x2C8311395Boost pressure sensor, plausibility: Pressure before throttle valve too highThe diagnostic function monitors the boost pressure.P0234Turbocharger/Supercharger 'A' Overboost Condition
0x2C8411396Boost pressure sensor, plausibility: Pressure before throttle valve too lowThe diagnostic function monitors the boost- pressure sensor.P0299Turbocharger/Supercharger 'A' Underboost Condition
0x2C8511397Boost pressure sensor, plausibility: Pressure before throttle valve too high when engine not
running
The diagnostic function monitors the boost pressure.P10F2Charge Air Pressure in Comparison to Barometric Pressure Too High
0x2C8611398Boost pressure sensor, plausibility: Pressure before throttle valve too low when engine not
running
The diagnostic function monitors the boost pressure.P10F3Charge Air Pressure in Comparison to Barometric Pressure Too Low
0x2C8811400Diverter valve, actuation: Short circuit to B+The diagnostic function monitors the wire to the compressor bypass valve.P0035Turbocharger/Supercharger Bypass Valve 'A' Control Circuit High
0x2C8911401Diverter valve, actuation: Short circuit to earthThe diagnostic function monitors the wire to the compressor bypass valve.P0034Turbocharger/Supercharger Bypass Valve 'A' Control Circuit Low
0x2C8A11402Diverter valve, actuation: Line disconnectionThe diagnostic function monitors the wire to the compressor bypass valve.P0033Turbocharger/Supercharger Bypass Valve 'A' Control Circuit
0x2C9011408Blow-off valve, mechanics: Jammed closedThe diagnostic function monitors the compressor bypass valve to determine if it is
seizing in its closed position.
0x2CA111425Wastegate valve, activation: Short circuit to B+The diagnostic function monitors the electrical wire from the DME to the electropneumatic
pressure converter.
P0246Turbocharger/Supercharger Wastegate Solenoid 'A' High
0x2CA211426Wastegate valve, activation: Short circuit to earthThe diagnostic function monitors the electrical wire from the DME to the electropneumatic
pressure converter.
P0245Turbocharger/Supercharger Wastegate Solenoid 'A' Low
0x2CA311427Wastegate valve, activation: Line disconnectionThe diagnostic function monitors the electrical wire from the DME to the electropneumatic
pressure converter.
P0243Turbocharger/Supercharger Wastegate Solenoid 'A'
0x2CED11501Oxygen sensor after catalytic converter, dynamics, from rich to lean: Slow responseThe diagnostic function monitors the dynamic response of the oxygen sensor behind the catalytic converter on overrun.P013AO2 Sensor Slow Response - Rich to Lean (Bank 1 Sensor 2)
0x2CEE11502Oxygen sensor heating before catalytic converter, function: Heater fault P102AO2 Sensor Heating, Heater Error (Bank 1 Sensor 1)
0x2CF411508Oxygen sensor before catalytic converter, dynamics: Slow responseThe diagnostic function monitors the dynamic response of the oxygen sensor before the catalytic converter.P0133O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
0x2CF811512Oxygen sensor before catalytic converter, installation: Sensor not connectedThe diagnostic function monitors correct installation of the oxygen sensor before the
P2414O2 Sensor Exhaust Sample Error (Bank 1 Sensor 1)
0x2CFA11514Oxygen sensor before catalytic converter, line fault: Line disconnection, Nernst cableThe diagnostic function monitors the internal resistance and the output voltage of the oxygen
P2243O2 Sensor Reference Voltage Circuit/Open (Bank 1 Sensor 1)
0x2CFF11519Oxygen sensor before catalytic converter, signal lines:Short circuit to B+The diagnostic function monitors the controller in the DME.P0132O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
0x2D0011520Oxygen sensor before catalytic converter, signal lines:Short circuit to earthThe diagnostic function monitors the controller in the DME.P0131O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
0x2D0311523DME, internal fault, oxygen sensor before catalytic converter: Oxygen-sensor module, signal-circuit adaptation values too highThe diagnostic function monitors the controller in the DME.P3012O2 Sensor Signal Circuit Adaptation Value Too High (Bank 1 Sensor 1)
0x2D0411524DME, internal fault, oxygen sensor before catalytic converter: Oxygen-sensor module,
undervoltage
The diagnostic function monitors the controller in the DME.P3014O2 Sensor WRAF-IC Supply Voltage Too Low (Bank 1 Sensor 1)
0x2D0511525DME, internal fault, oxygen sensor before catalytic converter: Initialisation errorThe diagnostic function monitors the controller in the DME.P3024O2 Sensor Initialization Error WRAF-IC (Bank 1 Sensor 1)
0x2D0611526DME, internal fault, oxygen sensor before catalytic converter: Communication faultThe diagnostic function monitors the controller in the DME.P3022O2 Sensor Disturbed SPI Communication to WRAF-IC (Bank 1 Sensor 1)
0x2D0B11531Oxygen sensor heating before catalytic converter, activation: Short circuit to B+The diagnostic function monitors activation of the heater for the oxygen sensor before the
P0032HO2S Heater Control Circuit High (Bank 1 Sensor 1)
0x2D0C11532Oxygen sensor heating before catalytic converter, activation: Short circuit to earthThe diagnostic function monitors activation of the heater for the oxygen sensor before the
P0031HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
0x2D0D11533Oxygen sensor heating before catalytic converter, activation: Line disconnectionThe diagnostic function monitors activation of the heater for the oxygen sensor before the
P0030HO2S Heater Control Circuit (Bank 1 Sensor 1)
0x2D0F11535Oxygen sensor heating after catalytic converter, activation: Short circuit to B+The diagnostic function monitors activation of the heater for the oxygen sensor behind the
P0038HO2S Heater Control Circuit High (Bank 1 Sensor 2)
0x2D1011536Oxygen sensor heating after catalytic converter, activation: Short circuit to earthThe diagnostic function monitors activation of the heater for the oxygen sensor behind the
P0037HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
0x2D1111537Oxygen sensor heating after catalytic converter, activation: Line disconnectionThe diagnostic function monitors activation of the heater for the oxygen sensor behind the
P0036HO2S Heater Control Circuit (Bank 1 Sensor 2)
0x2D1311539Oxygen sensor heating after catalytic converter, function: Internal resistance too highThe diagnostic function monitors the difference between the expected and the actual internal resistance in the heater for the oxygen sensor behind the catalytic converter.P0141O2 Sensor Heater Circuit (Bank 1 Sensor 2)
0x2D1511541 P013EO2 Sensor Delayed Response - Rich to Lean (Bank 1 Sensor 2)
0x2D1B11547Oxygen sensor after catalytic converter, system check: Signal fixed at leanThe diagnostic function monitors whether the voltage of the oxygen sensor behind catalytic
converter remains stuck at a low value.
P2270O2 Sensor Signal Biased/Stuck Lean (Bank 1 Sensor 2)
0x2D1C11548Oxygen sensor after catalytic converter, system check: Signal fixed at greaseThe diagnostic function monitors whether the voltage of the oxygen sensor behind catalytic
converter remains stuck at a high value.
P2271O2 Sensor Signal Biased/Stuck Rich (Bank 1 Sensor 2)
0x2D1F11551Oxygen sensor after catalytic converter, electrical: Short circuit to B+The diagnostic function monitors electrical status of the oxygen sensor behind catalytic
converter.
P0138O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
0x2D2011552Oxygen sensor after catalytic converter, electrical: Short circuit to earthThe diagnostic function monitors electrical status of the oxygen sensor behind catalytic
converter.
P0137O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
0x2D2211554Oxygen sensor after catalytic converter, electrical: Line disconnectionThe diagnostic function monitors the oxygen sensor behind catalytic converter.P0136O2 Sensor Circuit (Bank 1 Sensor 2)
0x2D2311555Oxygen sensor before catalytic converter, pump power cable : Oxygen sensor control
value above threshold due to open pump current cable
The diagnostic function monitors the voltage of the oxygen sensor before the catalytic
converter.
P3018O2 Sensor Lambda Controller Value Above Threshold due to Open Pumping Current Circuit (Bank 1 Sensor 1)
0x2D2411556Oxygen sensor before catalytic converter, in coasting/overrun mode: Signal outside limit
value
converter.
P2297O2 Sensor Out of Range During Deceleration (Bank 1 Sensor 1)
0x2D2511557Oxygen sensor before catalytic converter, line fault: Open circuit, pump current leadThe diagnostic function monitors the voltage of the oxygen sensor before the catalytic
converter.
P2237O2 Sensor Positive Current Control Circuit/Open (Bank 1 Sensor 1)
0x2D2711559Oxygen sensor before catalytic converter, line fault: Open circuit, virtual groundThe diagnostic function monitors the internal resistance and the output voltage of the oxygen
P2251O2 Sensor Negative Current Control Circuit/Open (Bank 1 Sensor 1)
0x2D2B11563Oxygen sensor before catalytic converter, electric Nernst cell resistance or ceramic
temperature implausible, line or heating fault
The diagnostic function monitors the temperature of the oxygen sensor before the
0x2D3311571Oxygen sensor before catalytic converter, system check: Signal fixed at leanThe diagnostic function monitors the voltage of the pre-catalyst oxygen sensor and compares it with the voltage of the oxygen sensor behind the catalytic converter (at lambda = 1).P2195O2 Sensor Signal Biased/Stuck Lean (Bank 1 Sensor 1)
0x2D3411572Oxygen sensor before catalytic converter, system check: Signal fixed at greaseThe diagnostic function monitors the voltage of the pre-catalyst oxygen sensor and compares it with the voltage of the oxygen sensor behind the catalytic converter (at lambda = 1).P2196O2 Sensor Signal Biased/Stuck Rich (Bank 1 Sensor 1)
0x2D4211586Valvetronic, adjustment range: Stop not learntThe diagnostic function determines whether a valid travel limit is reached during initialization of the Valvetronic system.P101AVVT-Self-Learning Function, Stops Not Learned
0x2D4311587Valvetronic, adjustment range: Fault range checkThe diagnostic function monitors whether the adjustment range has varied from the base learning data during the course of the vehicle's
service life.
P1023VVT-Self-Learning Function Faulty Adjustment Range (Bank 1)
0x2D4411588Valvetronic, adjustment range: Range check, deviation to master adaptationThe diagnostic function monitors the adjustment range during the check of the Valvetronic's
range.
0x2D5111601Intake VANOS solenoid valve, actuation: Short circuit to B+The diagnostic function monitors the wire to the VANOS solenoid valve.P2089'A' Camshaft Position Actuator Control Circuit High (Bank 1)
0x2D5211602Intake VANOS solenoid valve, actuation: Short circuit to earthThe diagnostic function monitors the wire to the VANOS solenoid valve.P2088'A' Camshaft Position Actuator Control Circuit Low (Bank 1)
0x2D5311603Intake VANOS solenoid valve, actuation: Line disconnectionThe diagnostic function monitors the wire to the VANOS solenoid valve.P0010'A' Camshaft Position Actuator Circuit/Open (Bank 1)
0x2D5411604Variable camshaft timing control (VANOS), exhaust, cold start not controllableThe diagnostic function monitors adjustment of the exhaust camshaft during the catalytic
converter's warm-up phase.
P054BCold Start 'B' Camshaft Position Timing Over- Retarded (Bank 1)
0x2D5511605Variable camshaft timing control (VANOS), intake, cold start: not controllableThe diagnostic function monitors adjustment of the intake-side camshaft during the catalytic
P052BCold Start 'A' Camshaft Position Timing Over- Retarded (Bank 1)
0x2D5A11610VANOS intake: control fault, camshaft stuckThe diagnostic function monitors the camshaft timing adjustment.P13C0'A' Camshaft Stuck
[TBODY] [/TBODY]
0x2D5B11611VANOS intake: Control fault, position not reachedThe diagnostic function monitors the camshaft timing adjustment.P0012'A' Camshaft Position - Timing Over-Retarded (Bank 1)
0x2D6011616VANOS, exhaust: control fault, camshaft stuckThe diagnostic function monitors the camshaft timing adjustment.P13C9'B' Camshaft Stuck
0x2D6111617VANOS, exhaust: Control fault, position not reachedThe diagnostic function monitors the camshaft timing adjustment.P0015'B' Camshaft Position - Timing Over-Retarded (Bank 1)
0x2D9B11675Exhaust VANOS solenoid valve, actuation: Short circuit to B+The diagnostic function monitors the wire to the VANOS solenoid valve.P2091'B' Camshaft Position Actuator Control Circuit High (Bank 1)
0x2D9C11676Exhaust VANOS solenoid valve, actuation: Short circuit to earthThe diagnostic function monitors the wire to the VANOS solenoid valve.P2090'B' Camshaft Position Actuator Control Circuit Low (Bank 1)
0x2D9D11677Exhaust VANOS solenoid valve, actuation: Line disconnectionThe diagnostic function monitors the wire to the VANOS solenoid valve.P0013'B' Camshaft Position - Actuator Circuit/Open (Bank 1)
0x2D9F11679Intake camshaft sensor: Signal implausibleThe diagnostic function monitors the intake camshaft position sensor.P0341Camshaft Position Sensor 'A' Circuit Range/Performance (Bank 1 or Single Sensor)
0x2DA011680Inlet camshaft: Angle offset with respect to crankshaft outside toleranceThe diagnostic function monitors the offset angle between crankshaft and camshaft.P1338Camshaft Position Sensor 'A' Faulty Phase Position (Bank 1)
0x2DA111681Exhaust camshaft sensor: Signal implausibleThe diagnostic function monitors the exhaust camshaft position sensor.P0366Camshaft Position Sensor 'B' Circuit Range/Performance (Bank 1)
0x2DA211682Exhaust camshaft: Angle offset with respect to crankshaft outside toleranceThe diagnostic function monitors the offset angle between crankshaft and camshaft.P1339Camshaft Position Sensor 'B' Faulty Phase Position (Bank 1)
0x2DB011696VANOS, exhaust: Intake camshaft not in locking position at start upThe diagnostic function monitors camshaft position locking.P1325B Camshaft Starting Position not Reached (Bank 1)
0x2DB111697VANOS intake: Intake camshaft not in locking position at start upThe diagnostic function monitors camshaft position locking.P1323A Camshaft Starting Position not Reached (Bank 1)
0x2DB411700Valvetronic relay, activation: Short circuit to B+The diagnostic function monitors electrical control-activation of the Valvetronic relay for a
short circuit to positive.
P10D8VVT-Relay Circuit High
0x2DB511701Valvetronic relay, activation: Short circuit to earthThe diagnostic function monitors electrical activation of the Valvetronic relay for short
circuits to ground.
P10D7VVT-Relay Circuit Low
0x2DB611702Valvetronic relay, activation: Line disconnectionThe diagnostic function monitors electrical activation of the Valvetronic relay for open
circuits.
P10D6VVT-Relay Circuit
0x2DBA11706Valvetronic, component protection, output stage System switch-offThe diagnostic function monitors the temperature of the driver circuit.P10DFVVT-Overload Protection Output Stage System Shutdown
0x2DBB11707Valvetronic, component protection servomotor: System switch-offThe diagnostic function monitors the temperature of the Valvetronic actuator motor.P10E0VVT-Overload Protection Control Motor System Shutdown
0x2DBC11708Valvetronic, eccentric shaft adaptation: Lower stop reachedOpen
0x2DBF11711Valvetronic servomotor, activation: Short circuit to B+The diagnostic function monitors the Valvetronic actuator motor's three phases for a short circuit
to positive.
P1047VVT-Control Circuit High (Bank 1)
0x2DC011712Valvetronic servomotor, activation: Short circuit to earthThe diagnostic function monitors the Valvetronic actuator motor's three phases for a short circuit
to ground.
P1048VVT-Control Circuit Low (Bank 1)
0x2DC311715Valvetronic servomotor, activation: Line disconnectionThe diagnostic function monitors the Valvetronic actuator motor's three phases for an open circuit in one of the wires.P1050VVT-Control Circuit (Bank 1)
0x2DCA11722Valvetronic, overload protection: output stage overloadedThe diagnostic function monitors the temperature of the driver circuit.P10E7VVT-Overload Protection Output Stage Overload
0x2DCB11723Valvetronic, overload protection: Actuator motor overloadedThe diagnostic function monitors the temperature of the Valvetronic actuator motor.P10E8VVT-Overload Protection Control Motor Overload
0x2DCE11726Valvetronic system: Control deviation too greatThe diagnostic function monitors the Valvetronic system's control precision.P1030VVT-Actuator Monitoring Position Control; Tight, no Adjustment possible (Bank 1)
0x2DCF11727Valvetronic system: no movement identifiedThe diagnostic function determines whether the Valvetronic system moves freely and without
resistance during the initialization routine.
P10E1VVT-System No Travel Detected
0x2DD611734Valvetronic servomotor, position sensors: Short- circuit or line break (open circuit)The diagnostic function monitors the wires to the five position sensors.P10E2VVT-Sensors Supply Voltage Circuit Electrical
0x2DD711735Valvetronic servomotor, position sensors: Supply voltage faultyThe diagnostic function monitors the power- supply wires to the position sensors.P10E6VVT-Sensors Supply Voltage Circuit Open
0x2DD811736Valvetronic servomotor, position sensors: Signal implausibleThe diagnostic function monitors the switching sequence of the position sensors.P1017VVT- Sensors Plausibility (Bank 1)
0x2DE111745
0x2DE211746 P10F4VVT-Control Phase U Circuit Open (Bank 1)
0x2DE311747 P10F5VVT-Control Phase V Circuit Open (Bank 1)
0x2DE411748 P10F6VVT-Control Phase W Circuit Open (Bank 1)
0x2DE511749 P10E8VVT-Overload Protection Control Motor Overload
0x2DE811752 P10DFVVT-Overload Protection Output Stage System Shutdown
0x2DE911753 P10E0VVT-Overload Protection Control Motor System Shutdown
0x2DEA11754 P10E7VVT-Overload Protection Output Stage Overload
0x2E0A11786Valvetronic servomotor, activation, voltage phase: Line disconnectionThe diagnostic function monitors activation of Phase U in the Valvetronic actuator motor for
open circuits.
0x2E0B11787Valvetronic servomotor, activation, volt phase: Line disconnectionThe diagnostic function monitors activation of Phase V in the Valvetronic actuator motor for
open circuits.
0x2E0C11788Valvetronic servomotor, activation, watt phase: Line disconnectionThe diagnostic function monitors activation of Phase W in the Valvetronic actuator motor for
indication of an open circuit.
0x2E0E11790Valvetronic servomotor, position sensors: Signals implausibleThe diagnostic function monitors the Valvetronic actuator motor's position sensors for
plausibility.
0x2E4A11850Exhaust gas flap, activation: Short circuit to B+The diagnostic function monitors the activation wire to the exhaust-gas flap.P0478Exhaust Pressure Control Valve 'A' High
0x2E4B11851Exhaust gas flap, activation: Short circuit to earthThe diagnostic function monitors the activation wire to the exhaust-gas flap.P0477Exhaust Pressure Control Valve 'A' Low
0x2E4C11852Exhaust gas flap, activation: Line disconnectionThe diagnostic function monitors the activation wire to the exhaust-gas flap.P0475Exhaust Pressure Control Valve 'A'
0x2E7C11900Radiator shutter, top: Hardware faultThe diagnostic function monitors the actor for the radiator vent slats.P14C5Controlled Upper Air Shutter Hardware Defect
0x2E7D11901Radiator shutter, top: mechanicalThe diagnostic function monitors the radiator vent slats to confirm freedom of motion.P14C4Controlled Upper Air Shutter Mechanical
0x2E7E11902Radiator shutter, top: no communicationThe diagnostic function monitors the actor for the radiator vent slats.U1130Lost Communication With Controlled Upper Air Shutter
0x2E8011904Radiator shutter, activation: Short circuit to B+The diagnostic function monitors the wiring harness to the radiator vent slats.P300AControlled Air Shutter Circuit High
0x2E8111905Radiator shutter, activation: Short circuit to earthThe diagnostic function monitors the wiring harness to the radiator vent slats.P300BControlled Air Shutter Circuit Low
0x2E8211906Radiator shutter, activation: Line disconnectionThe diagnostic function monitors the wiring harness to the radiator vent slats.P300CControlled Air Shutter Circuit/Open
0x2E8411908Radiator shutter, bottom, electrical: malfunctionThe diagnostic function monitors the activation wire leading to the lower radiator vent slat
assembly.
P14C6Controlled Lower Air Shutter Electrical
0x2EE012000Combustion misfiring, several cylinders: Fuel injection deactivationThe diagnostic function monitors whether multiple "combustion miss" malfunctions are logged in the course of a single driving cycle.P0300Random/Multiple Cylinder Misfire Detected
0x2EE112001Combustion misfiring, several cylinders: damaging exhaust gasThe diagnostic function monitors whether multiple "combustion miss" malfunctions are logged in the course of a single driving cycle.P0300Random/Multiple Cylinder Misfire Detected
0x2EE212002Combustion misfiring, several cylinders: damaging exhaust gas after start sequenceThe diagnostic function monitors whether multiple "combustion miss" malfunctions are logged in the course of a single driving cycle.P0300Random/Multiple Cylinder Misfire Detected
0x2EE412004Combustion misfiring, cylinder 1: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
signals (segment periods).
P0301Cylinder 1 Misfire Detected
0x2EE512005Combustion misfiring, cylinder 1: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EE612006Combustion misfiring, cylinder 1: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EE712007Combustion misfiring, cylinder 2: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
P0302Cylinder 2 Misfire Detected
0x2EE812008Combustion misfiring, cylinder 2: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EE912009Combustion misfiring, cylinder 2: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EEA12010Combustion misfiring, cylinder 3: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
P0303Cylinder 3 Misfire Detected
[TBODY] [/TBODY]
0x2EEB12011Combustion misfiring, cylinder 3: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EEC12012Combustion misfiring, cylinder 3: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EED12013Combustion misfiring, cylinder 4: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
P0304Cylinder 4 Misfire Detected
0x2EEF12015Combustion misfiring, cylinder 4: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EF012016Combustion misfiring, cylinder 4: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EF112017Combustion misfiring, cylinder 5: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
P0305Cylinder 5 Misfire Detected
0x2EF212018Combustion misfiring, cylinder 5: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EF312019Combustion misfiring, cylinder 5: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EF412020Combustion misfiring, cylinder 6: Fuel injection deactivationThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
P0306Cylinder 6 Misfire Detected
0x2EF512021Combustion misfiring, cylinder 6: damaging exhaust gasThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EF612022Combustion misfiring, cylinder 6: damaging exhaust gas after start sequenceThe diagnostic function monitors the duration of the combustion strokes and compares them with the remaining cylinders by assessing the rpm
0x2EFE12030 P0300Random/Multiple Cylinder Misfire Detected
0x2EFF12031 P0301Cylinder 1 Misfire Detected
0x2F0012032 P0302Cylinder 2 Misfire Detected
0x2F0112033 P0303Cylinder 3 Misfire Detected
0x2F0212034 P0304Cylinder 4 Misfire Detected
0x2F0312035 P0305Cylinder 5 Misfire Detected
0x2F0412036 P0306Cylinder 6 Misfire Detected
0x2F4412100Ignition circuit, supply voltage: Bank or engine failureThe diagnostic function simultaneously monitors the spark duration in all cylinders.
0x2F4512101Irregular operation, single cylinder filling: Torque contribution too lowThe diagnostic function monitors the ?
0x2F7612150Super-knocking, cylinder 1: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 1st cylinder.
P13A0Knock Control Fuel Cut-Off due to Super Knocking Cylinder 1
0x2F7712151Super-knocking, cylinder 2: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 2nd cylinder.
P13A1Knock Control Fuel Cut-Off due to Super Knocking Cylinder 2
0x2F7812152Super-knocking, cylinder 3: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 3rd cylinder.
P13A2Knock Control Fuel Cut-Off due to Super Knocking Cylinder 3
0x2F7912153Super-knocking, cylinder 4: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 4th cylinder.
P13A3Knock Control Fuel Cut-Off due to Super Knocking Cylinder 4
0x2F7A12154Super-knocking, cylinder 5: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 5th cylinder.
P13A4Knock Control Fuel Cut-Off due to Super Knocking Cylinder 5
0x2F7B12155Super-knocking, cylinder 6: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection
at the 6th cylinder.
P13A5Knock Control Fuel Cut-Off due to Super Knocking Cylinder 6
0x2F7C12156Super knocking: Injection switch-offThe diagnostic function responds to extreme combustion knock by deactivating the injection.P137FKnock Control Fuel Cut-Off due to Super Knocking
0x2F8312163Ignition timing adjustment in idle, cold start Ignition timing too earlyThe diagnostic function monitors the ignition angle while the catalytic converter is being
heated.
P050BCold Start Ignition Timing Performance
0x2F8412164Ignition timing adjustment at partial load, cold start: Ignition timing too earlyThe diagnostic function monitors the ignition angle while the catalytic converter is being
heated.
P13EACold Start Ignition Timing Performance Off Idle
0x2F8A12170Ignition, voltage supply: Short circuit to B+The diagnostic function monitors the power- supply wire providing voltage to the individual ignition coils from the overload-protection relay for ignition and injection, checking for open
wires and shorts to ground.
0x2F8B12171Ignition, voltage supply: Line disconnection or short circuit to earthThe diagnostic function monitors the power- supply wire providing voltage to the individual ignition coils from the overload-protection relay for ignition and injection, checking for open
0x2FA812200Combustion miss, cylinder 1: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FA912201Combustion miss, cylinder 2: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FAA12202Combustion misfiring, cylinder 3: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FAB12203Combustion miss, cylinder 4: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FAC12204Combustion miss, cylinder 5: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FAD12205Combustion misfiring, cylinder 6: Spark duration too shortThe diagnostic function monitors the spark duration.
0x2FDA12250Crankshaft sensor, signal: missingThe diagnostic function monitors the crankshaft sensor.P0335Crankshaft Position Sensor 'A' Circuit
0x2FDB12251Crankshaft sensor: Disturbed crankshaft signalThe diagnostic function monitors the crankshaft sensor.P0336Crankshaft Position Sensor 'A' Circuit Range/Performance
0x2FDD12253Crankshaft sensor, parked position: ImplausibleThe diagnostic function monitors the crankshaft sensor.P13CECrankshaft Parking Position Implausible
0x300C12300Intake camshaft sensor: Signal highThe diagnostic function monitors the intake camshaft position sensor.P0343Camshaft Position Sensor 'A' Circuit High (Bank 1 or Single Sensor)
0x300D12301Intake camshaft sensor: Signal lowThe diagnostic function monitors the intake camshaft position sensor.P0342Camshaft Position Sensor 'A' Circuit Low (Bank 1 or Single Sensor)
0x300E12302Exhaust camshaft sensor: Signal highThe diagnostic function monitors the exhaust camshaft position sensor.P0368Camshaft Position Sensor 'B' Circuit High (Bank 1)
0x300F12303Exhaust camshaft sensor: Signal lowThe diagnostic function monitors the exhaust camshaft position sensor.P0367Camshaft Position Sensor 'B' Circuit Low (Bank 1)
0x301112305Intake camshaft, mechanics: Assembly faultyThe diagnostic function monitors the installation position of the intake camshaft.P13CA'A' Camshaft Incorrect Assembly
0x301212306Exhaust camshaft, mechanical: Assembly faultyThe diagnostic function monitors the installation position of the exhaust camshaft.P13CB'B' Camshaft Incorrect Assembly
0x303E12350Knock control, fault check: Malfunction, system faultThe diagnostic function monitors the quality of the signals from the knock sensors.P0324Knock/Combustion Vibration Control System Error
0x303F12351Knock sensor, electrical: Signal, input A, short circuit to positiveThe diagnostic function monitors the sensor wire for short circuits.P13AFKnock Sensor 1 Circuit 'A' High (Bank 1)
0x304012352Knock sensor, electrical: Signal, input A, short circuit to groundThe diagnostic function monitors the sensor wire for short circuits.P13AEKnock Sensor 1 Circuit 'A' Low (Bank 1)
0x304112353Knock sensor, electrical: Signal, input B, short circuit to positiveThe diagnostic function monitors the sensor wire for short circuits.P13B9Knock Sensor 1 Circuit 'B' High (Bank 1)
0x304212354Knock sensor, electrical: Signal, input B, short circuit to groundThe diagnostic function monitors the sensor wire for short circuits.P13B8Knock Sensor 1 Circuit 'B' Low (Bank 1)
0x304312355Knock sensor 2, electrical: Signal, input A, short circuit to positiveThe diagnostic function monitors the sensor wire for short circuits.P13BFKnock Sensor 2 Circuit 'A' High (Bank 1)
0x304412356Knock sensor 2, electrical: Signal, input A, short circuit to groundThe diagnostic function monitors the sensor wire for short circuits.P13BEKnock Sensor 2 Circuit 'A' Low (Bank 1)
0x304512357Knock sensor 2, electrical: Signal, input B, short circuit to positiveThe diagnostic function monitors the sensor wire for short circuits.P13C8Knock Sensor 2 Circuit 'B' High (Bank 1)
0x304612358Knock sensor 2, electrical: Signal, input B, short circuit to groundThe diagnostic function monitors the sensor wire for short circuits.P13C7Knock Sensor 2 Circuit 'B' Low (Bank 1)
0x304812360Knock sensor, signal: Engine mechanically too loud or KS outside tolerance (sensitivity)The diagnostic function monitors the engine's noise level.P0328Knock/Combustion Vibration Sensor 1 Circuit High (Bank 1 or Single Sensor)
0x304912361Knock sensor, signal: Electrical fault KS (loose contact) or KS looseThe diagnostic function monitors the knock sensor's electrical signal.P0327Knock/Combustion Vibration Sensor 1 Circuit Low (Bank 1 or Single Sensor)
0x304C12364Knock sensor 2, signal: Engine mechanically too loud or KS outside tolerance (sensitivity)The diagnostic function monitors the engine's noise level.P1328Knock/Combustion Vibration Sensor 2 Circuit High (Bank 1)
0x304D12365Knock sensor 2, signal: Electrical fault KS (loose contact) or KS looseThe diagnostic function monitors the knock sensor's electrical signal.P1327Knock/Combustion Vibration Sensor 2 Circuit Low (Bank 1)
0x310612550Catalytic converter: Efficiency below limitThe diagnostic function monitors the ability of the catalytic converter to store oxygen.P0420Catalyst System Efficiency Below Threshold (Bank 1)
0x315512629Tank vent valve, activation: Short circuit to B+The diagnostic function monitors the control wire to the EVAP valve for short circuits to positive.P0459Evaporative Emission System Purge Control Valve 'A' Circuit High
0x315612630Tank vent valve, activation: Short circuit to earthThe diagnostic function monitors the control wire to the EVAP valve for short circuits to ground.P0458Evaporative Emission System Purge Control Valve 'A' Circuit Low
0x315712631Tank vent valve, activation: Line disconnectionThe diagnostic function monitors the control wire to the EVAP valve for an open circuit.P0444Evaporative Emission System Purge Control Valve 'A' Circuit Open
0x315A12634Fuel tank vent valve: jammed openThe diagnostic function monitors the flow through the fuel tank's EVAP vent line.P2421Evaporative Emission System Vent Valve Stuck Open
0x316012640Tank safety valve shut-off valve, activation: Short circuit to B+The diagnostic function monitors electrical activation of the tank cutoff valve.P149CEvaporative Emission System Shutoff Valve 2 Control Circuit High
0x316112641Tank safety valve shut-off valve, activation: Short circuit to earthThe diagnostic function monitors electrical activation of the tank cutoff valve.P149BEvaporative Emission System Shutoff Valve 2 Control Circuit Low
0x316212642Tank safety valve shut-off valve, activation: Line disconnectionThe diagnostic function monitors electrical activation of the tank cutoff valve.P149AEvaporative Emission System Shutoff Valve 2 Control Circuit
0x316312643Tank safety valve shut-off valve: jammed open P149DEvaporative Emission System Shutoff Valve 2 Stuck Off
0x316412644Tank safety valve: malfunctionOpenP0440Evaporative Emission System
0x316612646Tank safety valve: malfunctionThe diagnostic function monitors the flow through the fuel tank's EVAP vent line.P0440Evaporative Emission System
[TBODY] [/TBODY]
0x318312675Fuel level sensor, right, signal: Short circuit to B+The diagnostic function monitors the tank fuel- level sensor for a valid output signal within specified limits. The fault is first stored in the junction box electronics and then relayed to the
DME.
P2068Fuel Level Sensor 'B' Circuit High
0x318412676Fuel level sensor, right, signal: Short circuit to earthThe diagnostic function monitors the tank fuel- level sensor for a valid output signal within specified limits. The fault is first stored in the junction box electronics and then relayed to the
DME.
P2067Fuel Level Sensor 'B' Circuit Low
0x318512677Fuel level sensor, right, signal: CAN value implausibleThe diagnostic function monitors the message on the CAN bus to assess the plausibility of the
fuel level indicated by the right-side fuel-level sensor.
P1408Fuel Level Signal 2
0x318712679Fuel level sensor, left, signal: Short circuit to B+The diagnostic function monitors the tank fuel- level sensor for a valid output signal within specified limits. The fault is first stored in the junction box electronics and then relayed to the
DME.
P0463Fuel Level Sensor 'A' Circuit High
0x318812680Fuel level sensor, left, signal: Short circuit to earthThe diagnostic function monitors the tank fuel- level sensor for a valid output signal within specified limits. The fault is first stored in the junction box electronics and then relayed to the
DME.
P0462Fuel Level Sensor 'A' Circuit Low
0x318A12682Fuel level sensor, left, signal: CAN value implausibleThe diagnostic function monitors the message on the CAN bus to assess the plausibility of the
fuel level indicated by the left-side fuel-level sensor.
P1407Fuel Level Signal 1
0x318D12685Fuel level sensor: Deviation between consumption and fill-level changeThe diagnostic function monitors the drop in the tank's fuel level and compares it to the quantity of fuel injected into the engine during the same
period.
P144BFuel Level / Fuel Consumption Correlation
0x31E712775Electric fan, actuation: Short circuit to B+The diagnostic function monitors the wire between the electric fan and the DME.P0692Fan 1 Control Circuit High
0x31E812776Electric fan, actuation: Short circuit to earthThe diagnostic function monitors the wire between the electric fan and the DME.P0691Fan 1 Control Circuit Low
0x31E912777Electric fan, actuation: Line disconnectionThe diagnostic function monitors the wire between the electric fan and the DME.P0480Fan 1 Control Circuit
0x31EA12778Electric fan, self-diagnosis: Mechanical or hardware faultThe diagnostic function monitors operation of the electric fan.
0x321912825 P2420Evaporative Emission System Switching Valve Control Circuit High
0x321A12826 P2419Evaporative Emission System Switching Valve Control Circuit Low
0x321B12827 P2418Evaporative Emission System Switching Valve Control Circuit/Open
0x321C12828 P0442Evaporative Emission System Leak Detected (small leak)
0x321D12829 P0456Evaporative Emission System Leak Detected (very small leak)
0x321E12830 P1449Diagnostic Module Tank Leakage (DM-TL) Pump Current Too High
0x321F12831 P1448Diagnostic Module Tank Leakage (DM-TL) Pump Current Too Low
0x322012832 P1434Diagnostic Module Tank Leakage (DM-TL)
0x322112833 P1447Diagnostic Module Tank Leakage (DM-TL) Pump Current Too High during Switching Solenoid Test
0x322212834 P240CEvaporative Emission System Leak Detection Pump Heater Control Circuit High
0x322312835 P240BEvaporative Emission System Leak Detection Pump Heater Control Circuit Low
0x322412836 P240AEvaporative Emission System Leak Detection Pump Heater Control Circuit/Open
0x322512837 P2402Evaporative Emission System Leak Detection Pump Control Circuit High
0x322612838 P2401Evaporative Emission System Leak Detection Pump Control Circuit Low
0x322712839 P2400Evaporative Emission System Leak Detection Pump Control Circuit/Open
0x322812840 P143FEvaporative Emission System Afterrunning Diagnosis
0x32AB12971EWS-DME message incorrect Frame errorThe diagnostic function monitors communications on the CAN bus to assess
electronic immobilizer messages.
U1166Message Monitoring EWS (Electronic Immobilizer) - Frame Error
0x32C813000Poor-road-surface detection: Wheel speed too highThe diagnostic function monitors the signals from the wheelspeed sensors to determine if
they are valid.
P1518Rough Road Detection Wheel Speed Too High
0x32C913001Poor-road-surface detection: No wheel-speed signal receivedThe diagnostic function monitors reception of the message.P1517Rough Road Detection No Wheel Speed Signal
0x32CC13004Vehicle speed, plausibility: Instrument cluster has sent signal of invalidityThe diagnostic function determines whether the vehicle speed from the instrument cluster is
plausible.
0x32CD13005Vehicle speed, plausibility: DSC signal implausible in relation to instrument-cluster
display
plausible.
0x32D013008Vehicle speed: Signal too highThe diagnostic function determines whether the speed signal is within a plausible range.P0503Vehicle Speed Sensor 'A' Intermittent/Erratic/High
0x32D813016Vehicle speed, plausibility: Minimum speed under load not reachedThe diagnostic function monitors the plausibility of the speed signal.P152AVehicle Speed Sensor, Speed Too Low Compared to Reference under Load
0x32D913017Vehicle speed, plausibility: Minimum speed in coast mode not reachedThe diagnostic function monitors the plausibility of the speed signal while the overrun cutoff is
active.
P152BVehicle Speed Sensor, Speed Too Low Compared to Reference in Coast Down
0x32DA13018Vehicle speed, plausibility: Implausible roadspeed signalThe diagnostic function monitors the difference in signals from the left and right wheelspeed
sensors.
P0501Vehicle Speed Sensor 'A' Range/Performance
0x32DC13020Vehicle speed, rear left wheel sensor, plausibility: Signal implausibleThe diagnostic function monitors the signals from the wheelspeed sensors for plausibility.P15DCWheel Speed Sensor Rear/Left Range/Performance
0x32DD13021Vehicle speed, front left wheel sensor, plausibility: Signal implausibleThe diagnostic function monitors the signals from the wheelspeed sensors for plausibility.P15DAWheel Speed Sensor Front/Left Range/Performance
0x32DE13022Vehicle speed, rear right wheel sensor, plausibility: Signal implausibleThe diagnostic function monitors the signals from the wheelspeed sensors for plausibility.P15DDWheel Speed Sensor Rear/Right Range/Performance
0x32DF13023Vehicle speed, front right wheel sensor, plausibility: Signal implausibleThe diagnostic function monitors the signals from the wheelspeed sensors for plausibility.P15DBWheel Speed Sensor Front/Right Range/Performance
0x32E113025EWS tampering protection: no start value programmedThe diagnostic function determines whether a start value is programmed.P1667EWS (Electronic Immobilizer) Start Value not yet Programmed
0x32E213026EWS tampering protection: expected response implausibleThe diagnostic function determines whether a start value is programmed.P16CFEWS (Electronic Immobilizer) Implausible Response
0x32E313027EWS-DME interface Hardware faultThe diagnostic function monitors the electronic immobilizer messages.P165AEWS (Electronic Immobilizer) Interface to ECM, Hardware Error
0x32E413028EWS-DME interface Frame errorThe diagnostic function monitors the electronic immobilizer messages.P1660EWS (Electronic Immobilizer) Telegram Error
0x32E513029EWS-DME interface TimeoutThe diagnostic function monitors the electronic immobilizer messages.P1661Timeout EWS (Electronic Immobilizer)-Telegram
0x32E613030EWS-DME interface Receive error, CAS interfaceThe diagnostic function monitors the electronic immobilizer messages.
0x32E713031DME, internal fault: EWS data: no available memory possibilityThe diagnostic function monitors the electronic immobilizer messages.P165CEWS (Electronic Immobilizer) Data, No Available Storage Possibility
0x32E813032DME, internal fault: EWS data: Fault, activation- code storageThe diagnostic function monitors the electronic immobilizer messages.P165DEWS (Electronic Immobilizer) Data, Faulty Release Code Storage
0x32E913033DME, internal fault: EWS data: Checksum errorThe diagnostic function monitors the electronic immobilizer messages.P165EEWS (Electronic Immobilizer) Data, Checksum Error
0x32EA13034DME, internal fault: EWS data: Writing fault 'Secret Key'The diagnostic function monitors the electronic immobilizer messages.
0x32EC13036EWS-DME message incorrect TimeoutThe diagnostic function monitors communications on the CAN bus to assess
U0167Lost Communication With Vehicle Immobilizer Control Module
0x332513093Brake light switch, plausibility: Signal implausibleThe diagnostic function monitors the plausibility of the brake light switchP0571Brake Switch 'A' Circuit
0x332C13100Terminal 15_3, line from CAS, electrical: Short circuit to earth or line disconnectionThe diagnostic function monitors the redundant "Terminal 15 off" wire from the CAS to the DME for short circuits to ground and opens.P15B1Terminal 15 Sense Circuit Low
0x332D13101Terminal 15_3, line from CAS, electrical: Short circuit to B+The diagnostic function monitors the redundant "Terminal 15 off" wire from the CAS to the DME for short circuits to positive.P15B0Terminal 15 Sense Circuit High
0x332E13102Terminal 87_1, power supply switched by main relay, electrical: Short circuit to earth or line
disconnection
The diagnostic function monitors the voltage- supply wire to Terminals 15N_1 and KL87_1 for an open wire or short circuit to ground.P15D9Terminal 15N_1 / 87_1 Power Supply Circuit
0x332F13103Terminal 87_2, power supply switched by main relay, electrical: Short circuit to earth or line
disconnection
The diagnostic function monitors the voltage- supply wire to Terminals 15N_2 and KL87_2 for an open wire or short circuit to ground.P15EDTerminal 15N_2 / 87_2 Power Supply Circuit
0x33301310487_3Terminal , power supply switched by main relay, electrical: Short circuit to earth or line
disconnection
The diagnostic function monitors the voltage- supply wire to Terminals 15N_3 and KL87_3 for an open wire or short circuit to ground.P15F8Terminal 15N_3 / 87_3 Power Supply Circuit
0x335B13147
0x335C13148
0x335D13149
0x339213202Engine switch-off time, plausibility: Time to short in correlation to engine-coolant coolingThe diagnostic function monitors the engine's calculated downtime by comparing it with the drop in coolant temperature while the engine is stationary.P15E8External Engine Off Timer Engine Off Time Too Short in Correlation to Cooling-Down Of Engine
Coolant
0x339313203Engine switch-off time, plausibility: Time to long in correlation to engine-coolant coolingThe diagnostic function monitors the engine's calculated downtime by comparing it with the drop in coolant temperature while the engine is stationary.P15E9External Engine Off Timer Engine Off Time Too Long in Correlation to Cooling-Down Of Engine
Coolant
0x339413204Engine switch-off time: Too fast during engine operationThe diagnostic function compares the internal timers of the DME and the instrument cluster
while the engine is running.
P15FAExternal Engine Off Timer Incrementation Too Fast During Engine Running
0x339513205Engine switch-off time: Too slow during engine operationThe diagnostic function compares the internal timers of the DME and the instrument cluster
P15FBExternal Engine Off Timer Incrementation Too Slow During Engine Running
0x339613206Engine switch-off time, signal: missingThe diagnostic function monitors transmission of the CAN time signal from the instrument
cluster. Diagnosis is interlocked by CAN fault.
P15FEExternal Engine Off Timer No Signal
0x339813208Engine switch-off time: Too fast during after-runThe diagnostic function compares the internal timers of the DME and the instrument cluster when the ignition is switched on again while the control module is in its shutdown phase.P15FCExternal Engine Off Timer Incrementation Too Fast During ECM Afterrunning
0x339913209Engine switch-off time: Too slow during after-runThe diagnostic function compares the internal timers of the DME and the instrument cluster when the ignition is switched on again while the control module is in its shutdown phase.P15FDExternal Engine Off Timer Incrementation Too Slow During ECM Afterrunning
0x33DC13276
0x33DD13277
0x33DE13278
[TBODY] [/TBODY]
0x33DF13279
0x33E013280
0x33E113281
0x33FC13308Oil-pressure control, dynamic Pressure variationsThe diagnostic function monitors the oscillation characteristics of the oil pressure.P159EEngine Oil Pressure Control, Dynamic, Pressure Fluctuations
0x33FD13309Engine oil pressure control, static: Engine oil pressure too high, emergency operationThe diagnostic function monitors the oil pressure.P159FEngine Oil Pressure Control, Static, Switchover To Limp Home Operation Because Engine Oil
Pressure Too High in Map Operation
0x33FE13310Engine oil pressure control, static: oil pressure too low, emergency operationThe diagnostic function monitors the oil pressure.P15A0Engine Oil Pressure Control, Static, Switchover To Limp Home Operation Because Engine Oil
Pressure Too Low in Map Operation
0x33FF13311Oil pressure control valve, activation: Short circuit to B+The diagnostic function monitors the wire from the DME to the oil-pressure control valve for shorts to positive.P15ECEngine Oil Pressure Control Valve Circuit High
0x340013312Oil pressure control valve, activation: Short circuit to earthThe diagnostic function monitors the wire from the DME to the oil-pressure control valve for
shorts to ground.
P15EBEngine Oil Pressure Control Valve Circuit Low
0x340113313Oil pressure control valve, activation: Line disconnectionThe diagnostic function monitors the wire from the DME to the oil-pressure control valve for
open circuits.
P15EAEngine Oil Pressure Control Valve Circuit/Open
0x340513317Oil pump, mechanical Oil pressure too highThe diagnostic function monitors the oil pressure.P15A3Engine Oil Pressure Too High
0x340613318Oil pump, mechanical Oil pressure too lowThe diagnostic function monitors the oil pressure.P0524Engine Oil Pressure Too Low
0x340813320Oil-pressure control valve, mechanical: hangs in fully energized position (minimum oil pressure)The diagnostic function monitors the oil pressure.P15A1Engine Oil Pressure Control, Mechanical, Solenoid Valve Sticking In Fully Energized Position (Minimum Oil Pressure)
0x340913321Oil-pressure control valve, mechanical: stuck in de-energized position (maximum oil pressure)The diagnostic function monitors the oil pressure.P15A2Engine Oil Pressure Control, Mechanical,
Solenoid Valve Sticking In De-Energized Position (Maximum Oil Pressure)
0x342613350Engine oil pressure sensor, electrical: Short circuit to B+The diagnostic function monitors the upper voltage limit of the engine oil-pressure sensor.P0523Engine Oil Pressure Sensor/Switch 'A' High
0x342713351Engine oil pressure sensor, electrical: Short circuit to earthThe diagnostic function monitors the engine oil- pressure sensor's lower voltage limit.P0522Engine Oil Pressure Sensor/Switch 'A' Low
0x342B13355Engine oil pressure sensor, plausibility: Signal frozenThe diagnostic function monitors the oil pressure.P0521Engine Oil Pressure Sensor/Switch 'A' Range/Performance
0x343F13375Oil condition sensor, electrical: Level malfunctionThe diagnostic function monitors the oil condition sensor.P1587Engine Oil Quality Sensor Level Measurement
0x344013376Oil condition sensor, electrical: Temperature malfunctionThe diagnostic function monitors the oil temperature signal to detect electrical faults.P1586Engine Oil Quality Sensor Temperature Measurement
0x344613382BSD message from the oil condition sensor: missingThe diagnostic function monitors the BSD message from the oil level sensor (QLT).P1521Engine Oil Quality Sensor Communication Error
0x344713383Engine oil level: Too lowThe diagnostic function monitors the engine oil level.P250FEngine Oil Level Too Low
0x344913385Oil condition sensor, electrical: malfunctionThe diagnostic function monitors the signal from the oil condition sensor for electrical faults.P252AEngine Oil Quality Sensor Circuit
0x344C13388Engine oil temperature sensor, electrical: malfunctionThe diagnostic function monitors the signal from the engine oil temperature sensor for electrical
malfunctions.
P0195Engine Oil Temperature Sensor 'A' Circuit
0x344E13390
0x344F13391
0x348A13450Characteristic map thermostat, mechanical: jammed openThe diagnostic function monitors the rise in coolant temperature at the engine's discharge
connection.
P0128Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
0x348E13454Map thermostat, activation: Short circuit to B+The diagnostic function monitors activation of the program map thermostat.P0599Thermostat Heater Control Circuit High
0x348F13455Map thermostat, activation: Short circuit to earthThe diagnostic function monitors activation of the program map thermostat.P0598Thermostat Heater Control Circuit Low
0x349013456Map thermostat, activation: Line disconnectionThe diagnostic function monitors activation of the program map thermostat.P0597Thermostat Heater Control Circuit/Open
0x34A313475
0x34A513477
0x34A813480
0x34A913481
0x34AD13485
0x34AE13486
0x34AF13487
0x352013600Idle speed control: Engine speed too highThe diagnostic function monitors the idle speed when the engine is warmed to normal operating temperature.P0507Idle Control System RPM Higher Than Expected
0x352113601Idle speed control: Engine speed too lowThe diagnostic function monitors the idle speed when the engine is warmed to normal operating temperature.P0506Idle Control System RPM Lower Than Expected
0x352413604Idle speed control, cold start: Engine speed too highThe diagnostic function monitors the idle speed during the catalytic converter's warmup phase.P1562Cold Start Idle Air Control System RPM Higher Than Expected (Bank 1)
0x352513605Idle speed control, cold start: Engine speed too lowThe diagnostic function monitors the idle speed during the catalytic converter's warmup phase.P1561Cold Start Idle Air Control System RPM Lower Than Expected (Bank 1)
0x352813608Monitoring engine torque limitation: Maximum permitted nominal torque is continuously
exceeded
The diagnostic function monitors the maximum approved specified torque.
0x352913609Engine-speed limitation with stationary vehicle: Idle speed too high for too longThe diagnostic function monitors the engine for overheating while the vehicle is stationary.
0x352A13610
0x358413700DME, internal fault, interior-temperature sensor: value too highThe diagnostic function monitors control module temperature for violation of an upper limit.P0634Control Module Internal Temperature 'A' Too High
0x358513701DME, internal fault, interior-temperature sensor: value too lowThe diagnostic function monitors control module temperature for violation of a lower limit.P163APCM/ECM/TCM Internal Temperature Too Low
0x358613702DME temperature: excess temperatureThe diagnostic function monitors the interior temperature of the DME.P0634Control Module Internal Temperature 'A' Too High
0x36B014000DME, internal fault, activation Valvetronic: malfunctionThe diagnostic function monitors the current flow through the Valvetronic actuator motor when the driver circuit is switched off.P10E5Internal Control Module Error, Control Circuit VVT
0x36B514005DME, internal fault: Delete EEPROM faultyThe diagnostic function monitors the EEPROM emulation's "delete sector."P062FInternal Control Module EEPROM Error
0x36B814008DME, internal fault: Monitoring-module faultThe diagnostic function monitors the DME's internal monitor modules.P060AInternal Control Module Monitoring Processor Performance
0x36BB14011DME, internal fault, watchdog output: malfunctionThe diagnostic function monitors the internal ABE and WDA wire in the DME.P16EAInternal Control Module Watchdog Error
0x36BC14012DME, internal fault, watchdog output: faulty question/answer communicationThe diagnostic function monitors the internal WDA wire in the DME.P16EBInternal Control Module Watchdog Communication Error
0x36BD14013DME, internal fault, watchdog output: Overvoltage detectionThe diagnostic function monitors the internal ABE wire in the DME.P16ECInternal Control Module Watchdog Overvoltage Error
0x36BE14014Encoding: Version not foundThe diagnostic function monitors the encoding.
0x36BF14015
0x36C014016DME, internal fault, electric accelerator pedal monitoring: A/D converter idling test pulse
check
The diagnostic function monitors the DME's internal status.P326AControl Module Monitoring Safety Function A/D Converter Error
0x36C114017DME, internal fault, electric accelerator pedal monitoring: AD converter, test voltage checkThe diagnostic function monitors the DME's internal status.P326AControl Module Monitoring Safety Function A/D Converter Error
0x36C214018DME, internal fault, electric accelerator pedal monitoring: Air quantity adjustmentThe diagnostic function monitors the DME's internal status.P326BControl Module Monitoring Safety Function Air Flow Adjustment
0x36C314019DME, internal fault: monitoring of signal plausibility, accelerator pedal module or pedal
sensor
The diagnostic function monitors the DME's internal status.P060DInternal Control Module Accelerator Pedal Position Performance
0x36C414020DME, internal fault, electric accelerator pedal monitoring: Speed sensorThe diagnostic function monitors the DME's internal status.P325CControl Module Monitoring Safety Function Speed Sensor Error
0x36C514021DME, internal fault: Monitoring plausibility of mixture correction factorsThe diagnostic function monitors the DME's internal status.P3237Control Module Monitoring Fuel Correction Error
0x36C614022DME, internal fault: Monitoring fuel injection quantity limit level 1The diagnostic function monitors the DME's internal status.P325DControl Module Monitoring Injection Rate Limitation Error
0x36C714023DME, internal fault: Monitoring injection-rate limitation level 2The diagnostic function monitors the DME's internal status.P325DControl Module Monitoring Injection Rate Limitation Error
0x36C814024DME, internal fault: Monitoring of the nominal oxygen sensor valueThe diagnostic function monitors the DME's internal status.P3337Control Module Monitoring Lambda Plausibility
0x36C914025DME, internal fault: Plausibility monitoring of the relative fuel massThe diagnostic function monitors the DME's internal status.P325FControl Module Monitoring Fuel Volume Plausibility
0x36CA14026DME, internal fault: Torque comparison monitoringThe diagnostic function monitors the DME's internal status.P061BInternal Control Module Torque Calculation Performance
0x36CB14027DME, internal fault, electric accelerator pedal monitoring: Drive train transmission ratio
implausible
The diagnostic function monitors the DME's internal status.P326CControl Module Monitoring Safety Function Ratio Error
0x36CC14028DME, internal fault: Monitoring, variant codingThe diagnostic function monitors the DME's internal status.P3235Control Module Monitoring Version Coding Plausibility
0x36CD14029DME, internal fault, electric accelerator pedal monitoring: Ignition-timing monitoringThe diagnostic function monitors the DME's internal status.P325EControl Module Monitoring Safety Function Ignition Timing Error
0x36CE14030DME, internal fault: Switch-off path test by monitoring moduleThe diagnostic function monitors the DME's internal status.P326DControl Module Monitoring Shutdown Path Error
0x36CF14031DME, internal fault: Plausibility monitoring, fuel massThe diagnostic function monitors the DME's internal status.P325FControl Module Monitoring Fuel Volume Plausibility
0x36D014032DME, internal fault, monitoring MSC communication Malfunction in module R2S2/1The diagnostic function monitors communications within the DME.P1646Internal Control Module Communication Error Output Stage
[TBODY] [/TBODY]
0x36D214034DME, internal fault, monitoring MSC communication Malfunction in module R2S2/2The diagnostic function monitors communications of DME hardware components.P1646Internal Control Module Communication Error Output Stage
0x36D414036 P10E5Internal Control Module Error, Control Circuit VVT
0x36E214050DME, internal fault, monitoring 5V sensor supply: Voltage outside valid rangeThe diagnostic function monitors the sensor voltage supply G1.P16E7Internal Control Module Volt Supply Voltage 1 Performance
0x36E314051DME, internal fault, monitoring 5V sensor supply 2: Voltage outside valid rangeThe diagnostic function monitors the internal sensor supply voltage G2.P16E8Internal Control Module Volt Supply Voltage 2 Performance
0x36E414052DME, internal fault, monitoring 5V sensor supply 3: Voltage outside valid rangeThe diagnostic function monitors the internal sensor supply voltage G2.P16E9Internal Control Module Volt Supply Voltage 3 Performance
0x36FA14074Starter motor, activation: Short circuit to B+The diagnostic function monitors the starter control-activation wire (Terminal 50) from the
DME to the CAS.
P0617Starter Relay Circuit High
0x36FB14075Starter motor, activation: Short circuit to earthThe diagnostic function monitors the starter control-activation wire (Terminal 50) from the
DME to the CAS.
P0616Starter Relay Circuit Low
0x36FC14076Starter motor, activation: Line disconnectionThe diagnostic function monitors the starter control-activation wire (Terminal 50) from the
DME to the CAS.
P0615Starter Relay Circuit
0x36FD14077DME main relay: implausibly openThe diagnostic function monitors the switch status of the main DME relay.
0x36FE14078DME main relay, activation Short circuit to earthThe diagnostic function monitors the switch status of the main DME relay.
0x36FF14079DME main relay: implausibly closedThe diagnostic function monitors the switch status of the main DME relay.
0x371414100Vehicle voltage, DME main relay: Voltage too highThe diagnostic function monitors the battery voltage relative to an upper limit.P0687ECM/PCM Power Relay Control Circuit High
0x371914105Valvetronic relay, supply voltage: Short circuit to earthThe diagnostic function monitors the wire from the Valvetronic relay to the DME for short
circuits to ground.
P10E3VVT-Relay Supply Voltage Circuit Low
0x371A14106Valvetronic relay, supply voltage: Line disconnectionThe diagnostic function monitors the wire from the Valvetronic relay to the DME for open wires, and monitors the control wire to the Valvetronic relay for open wires and shorts to ground.P10E4VVT-Relay Supply Voltage Circuit/Open
0x371B14107Relay, ignition and injection systems, activation: Short circuit to earthThe diagnostic function monitors the wire to the overload-protection relay for ignition and
injection.
0x371C14108Relay, ignition and injection systems, activation: Short circuit to B+The diagnostic function monitors the wire to the overload-protection relay for ignition and
injection.
0x371E14110Relay, ignition and injection systems, activation: Line disconnectionThe diagnostic function monitors the wire to the overload-protection relay for ignition and
injection.
0x375A14170CBS client: Output of substitute valueThe diagnostic function monitors calculation of milage remaining in the engine oil service
interval.
0x375B14171CBS client: Jump in availabilityThe diagnostic function monitors whether a jump in the availability has taken place.
0x375C14172DME, protection against tampering: Program or data manipulation detectedThe diagnostic function monitors the program status for signs of manipulation.
0x375F14175Incorrect data record: CAN timeoutThe diagnostic function monitors the CAN bus between the CAS and DME.
0x376014176Incorrect data record: Variant monitoringThe diagnostic function monitors the software versions in the CAS and DME.
0x377814200Coolant pump, shutdown: internal temperature too highThe diagnostic function monitors the temperature of the electric water pump's
electronics.
P15D1Coolant Pump Cut-Off, Internal Temperature Too High
0x377914201Coolant pump, shutdown: Overvoltage detectedThe diagnostic function monitors the power- supply voltage to the electric water pump.P15D2Coolant Pump Cut-Off, Overvoltage
0x377A14202Coolant pump, shutdown: Pump blockedThe diagnostic function monitors the electric water pump for mechanical seizure.
0x377B14203Coolant pump, operation with reduced output: Dry-running detectedThe diagnostic function monitors the electric water pump for cavitation.P15D4Coolant Pump Dry Run
0x377C14204Coolant pump, operation with reduced output: Undervoltage detectedThe diagnostic function monitors the power- supply voltage to the electric water pump.P15D5Coolant Pump Undervoltage
0x377D14205Coolant pump, operation with reduced output: Temperature limit 1 exceededThe diagnostic function monitors the temperature of the water pump's electronics.P15D6Coolant Pump Temperature Threshold 1 Exceeded
0x377E14206Coolant pump, operation with reduced output: Temperature limit 2 exceededThe diagnostic function monitors the temperature of the water pump's electronics.P15D7Coolant Pump Temperature Threshold 2 Exceeded
0x378F14223BSD message from electric coolant pump: missingThe diagnostic function monitors BSD bus communications with the electric water pump.
0x379114225Coolant pump, emergency operation input: No voltageThe diagnostic function monitors the voltage level at the electric water pump's emergency
backup input terminal.
0x379214226Coolant pump, speed deviation: outside toleranceThe diagnostic function monitors the rotation speed of the electric water pump.
0x379614230Clutch switch, signal: No signalThe diagnostic function monitors the clutch switch.
0x384014400Alternator, electrical: malfunctionThe diagnostic function monitors whether the alternator is supplying power.P0620Generator Control Circuit
0x384114401 P0620Generator Control Circuit
0x384214402
0x384314403
0x384414404Alternator, plausibility, electrical: CalculatedThe diagnostic function monitors the voltage of the onboard electrical system and compares it with the specified alternator voltage.P325AGenerator Electrical Error Calculated
0x384514405
0x384614406
0x384814408Alternator, temperature: excess temperatureThe diagnostic function monitors the alternator temperature.P0A3BGenerator Over Temperature
0x384C14412Alternator, plausibility, temperature: Excess temperature calculatedThe diagnostic function monitors the alternator temperature.P324CGenerator Over Temperature Calculated
0x385014416Alternator, mechanical: malfunctionThe diagnostic function monitors the alternator's rotation speed.P3223Generator Mechanical
0x385414420Alternator, controller: Incorrect typeThe diagnostic function monitors the regulator code and compares it with the specified value
stored in the DME.
P324EGenerator Regulator Type Implausible
0x385814424Generator: Incorrect typeThe diagnostic function monitors alternator's code and compares it with the specified value.P324AGenerator Type Implausible
0x385C14428Alternator, communication: no communicationThe diagnostic function monitors communications between DME and alternator.
0x385D14429
0x385F14431
0x386514437BSD busCommunication faultThe diagnostic function monitors the BSD bus.
0x386614438BSD busCommunication fault between DME and IBSThe diagnostic function monitors communications between the BSD bus and the
DME/DDE.
0x387214450 The diagnostic function monitors aging of the vehicle battery.
0x387314451 The diagnostic function monitors deep-discharge events in the vehicle battery.
0x387514453
0x387614454
0x387714455Power management, vehicle electrical system: OvervoltageThe diagnostic function monitors the onboard electrical system's voltage at the DME while the
engine is running.
P160CPowermanagement Overvoltage
0x387814456Power management, vehicle electrical system: UndervoltageThe diagnostic function monitors the electrical system voltage at the DME/DDE with the
engine running.
P160DPowermanagement Undervoltage
0x387914457Power management, vehicle electrical system: Battery-free operationThe diagnostic function monitors the electrical system voltage at the DME/DDE with the
engine running.
P160EPowermanagement Operation Without Charging of Battery
0x387C14460Power management, battery: Exhaustive battery chargeThe diagnostic function monitors the electrical system voltage at the DME/DDE.P160APowermanagement Exhaustive Discharge
0x387D14461Power management, battery: Power management faultyThe diagnostic function monitors the battery's charge status in the transport mode.
0x387F14463Power management, closed-circuit current violationThe diagnostic function monitors the standby current draw.P160FPowermanagement No-Load Current Error
[TBODY] [/TBODY]
0x388614470System voltage: Voltage too highThe diagnostic function monitors the electrical system voltage relative to an upper limit value.P0563System Voltage High
0x388714471System voltage: Voltage too lowThe diagnostic function monitors the battery voltage relative to a lower limit.P0562System Voltage Low
0x388814472System voltage: Analogue-digital converter faultyThe diagnostic function monitors the voltage of the analog-digital converter.P0560System Voltage
0x38A414500Intelligent battery sensor (IBS): Communication faultThe diagnostic function monitors expanded communications between the IBS and DME on the LIN bus.
0x38A714503Intelligent battery sensor (IBS): Version not plausibleThe diagnostic function monitors compatibility of the IBS version with the power management
in the DME/DDE.
P15CFBattery Sensor Variant Plausibility
0x38A814504Intelligent battery sensor (IBS): Internal faultThe diagnostic function monitors internal system functions in the IBS.
0x38A914505Intelligent battery sensor (IBS): Temperature measurement faultyThe diagnostic system plausibilizes the IBS temperature measurement.P150DBattery Sensor Temperature Error
0x38AA14506Intelligent battery sensor (IBS): Voltage measurement erroneousThe diagnostic system plausibilizes the IBS voltage measurement.P150EBattery Sensor Voltage Error
0x38AB14507Intelligent battery sensor (IBS): Current measurement erroneousThe diagnostic system plausibilizes the IBS current measurement.P150FBattery Sensor Current Error
0x38AC14508Intelligent battery sensor (IBS): Wake-up line, short to groundL4: The diagnostic function monitors the wake- up wire
L6: The diagnostic function monitors the wake- up wire to the junction box electronics.
0x38B214514Intelligent battery sensor (IBS): Wake-up line, level implausibleL4: The diagnostic function monitors the wake- up wire
P151BBattery Sensor Wakeup Circuit
0x38B414516BSD: No message from intelligent battery sensor (IBS)The diagnostic function monitors BSD bus communications with the DME.
0x38D614550Active engine mount, electrical: Short circuit to B+The diagnostic function monitors the wire from the DME to the engine mount for shorts to
positive.
P0A16Engine Mount 'A' Control Circuit High
0x38D714551Active engine mount, electrical: Short circuit to earthThe diagnostic function monitors the wire from the DME to the engine mount for shorts to
ground.
P0A15Engine Mount 'A' Control Circuit Low
0x38D814552Active engine mount, electrical: Line disconnectionThe diagnostic function monitors the electrical wire from the DME to the engine mount for
opens.
P0A14Engine Mount 'A' Control Circuit/Open
0x38EF14575Enable line, MSA, activation Short circuit to B+The diagnostic function monitors the enable wire for the MSA start request.
0x38F014576Enable line, MSA, activation Short circuit to earthThe diagnostic function monitors the enable wire for the MSA start request.
0x38F114577Enable line, MSA, activation Line disconnectionThe diagnostic function monitors the enable wire for the MSA start request.
0x38F214578
0x38F314579
0x390814600 The diagnostic function monitors the 'auxiliary battery charging unit.'
0x390914601 The diagnostic function monitors the wire and its shielding between the 'auxiliary battery charging unit' and the auxiliary battery.
0x390A14602 The diagnostic function monitors the auxiliary battery for the electric power steering.
0x390B14603 The diagnostic function monitors the battery separator, the wires between vehicle battery and auxiliary battery, and the charge status of the auxiliary battery.
0x390C14604
0x390D14605
0x390E14606
0x3B5215186
0x3B5715191
0x3B9915257
0x3B9A15258Coolant pump, LIN communication: Invalid messageThe diagnostic function monitors BSD bus communications with the electric water pump.
0x3B9B15259
0x3B9C15260
0x3B9D15261
0x3BC415300PT-CAN, message (ARS control unit):Alive checkThe diagnostic function monitors the currency of the message.
0x3BC515301PT-CAN, message (ARS control unit):missingThe diagnostic function monitors reception of the message.
0x3BC615302PT-CAN, message (ARS control unit):Checksum incorrectThe diagnostic function monitors the checksum of the message.
0x3BC715303PT-CAN, message (CAS control unit):missingThe diagnostic function monitors reception of the message.
0x3BC815304PT-CAN, message (CAS control unit):Checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BCC15308PT-CAN, message (IHKA control unit):missingThe diagnostic function monitors reception of the message.
0x3BCD15309PT-CAN, message (instrument panel control unit):Alive checkThe diagnostic function monitors the currency of the message.
0x3BCE15310PT-CAN, message (instrument panel control unit):missingThe diagnostic function monitors reception of the message.
0x3BCF15311PT-CAN, message (instrument panel control unit):MIL activation implausibleThe diagnostic function monitors the status of the emissions warning lamp.
0x3BD015312PT-CAN, message (request torque DSC, 0B6): checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BD115313PT-CAN, no message (request torque DSC, 0B6):The diagnostic function monitors reception of the message.
0x3BD215314PT-CAN, message (wheel speed, 0CE): missingThe diagnostic function monitors reception of the message.U116DLost Communication With Wheel Speed
0x3BD315315PT-CAN, message (transmission data 4, 10A): Checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BD415316PT-CAN, message (transmission data 4, 10A): missingThe diagnostic function monitors reception of the message.
0x3BD515317PT-CAN, message (status DSC, 19E) missingThe diagnostic function monitors reception of the message.U1126Lost Communication With DSC Status
0x3BD615318PT-CAN, message (vehicle speed, 1A0): checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.U11CAMessage Monitoring Speed Alive Check/Check Sum Error
0x3BD715319PT-CAN, no message (vehicle speed, 1A0):The diagnostic function monitors reception of the message.U1118Lost Communication With Speed
0x3BD815320PT-CAN, no message (transmission data 2, 1A2):The diagnostic function monitors reception of the message.
0x3BD915321PT-CAN, message (DKG status, 37D): missingThe diagnostic function monitors reception of the message.
0x3BDA15322PT-CAN, message (transmission data 3, 3B1): checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BDB15323PT-CAN, no message (transmission data 3, 3B1):The diagnostic function monitors reception of the message.
0x3BDC15324PT-CAN, message (electronic transmission control torque request, B5): checksum wrong/
alive check
The diagnostic function monitors the currency and the checksum of the message.U11C9Message Monitoring Torque Request ETC Check Sum Error/Alive Check
0x3BDD15325PT-CAN, no message (electronic transmission control torque request, B5):The diagnostic function monitors reception of the message.U110FLost Communication With Torque Request ETC
0x3BDE15326PT-CAN, message (twin-clutch gearbox torque request, B8): checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BDF15327PT-CAN, no message (twin-clutch gearbox torque request, B8):The diagnostic function monitors reception of the message.
0x3BE015328PT-CAN, message (gearbox data, BA): Checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BE115329PT-CAN, message (gearbox data, BA): missingThe diagnostic function monitors the wire for voltage supply of Terminal 15N_3 and Terminal
KL87_3.
0x3BE215330PT-CAN, message (twin-clutch gearbox speed control, B8): monitoring interventionThe diagnostic function monitors the requested intervention force of the throttle valve sensor
0x3BE715335
0x3BEC15340PT-CAN, message (cruise control operation, 194): Checksum wrong/ alive checkThe diagnostic function monitors the currency and the checksum of the message.
0x3BED15341PT-CAN, message (cruise control operation, 194): missingThe diagnostic function monitors reception of the message.
0x3BF015344
0x3BF115345
0x3BF415348
0xCD8352611Energy-saving mode: ActiveThe diagnostic function monitors whether the transport mode is active.
0xCD8552613PT-CAN, message (terminal status, 130): Checksum incorrectThe diagnostic function monitors the currency and the checksum of the message.
[TBODY] [/TBODY]
0xCD8652614PT-CAN, message (terminal status, 130): missingThe diagnostic function monitors reception of the message.
0xCD8752615PT-CAN communication fault: CAN bus Off or CAN bus faultyThe diagnostic function monitors the PT CAN.P3202Powertrain CAN, CAN Chip Cut-Off
0xCD8952617PT-CAN, message (status, crash deactivation, electric fuel pump, 135): missingThe diagnostic function monitors reception of the message.
0xCD8B52619PT-CAN, message (parking brake position request, 1A7): checksum wrongThe diagnostic function monitors the currency and the checksum of the message.
0xCD8C52620PT-CAN, no message (parking brake position request, 1A7):The diagnostic function monitors reception of the message.
0xCD8F52623PT-CAN, no message (gearbox data display, 1D2):The diagnostic function monitors reception of the message.
0xCD9152625PT-CAN, message (parking brake status, 201): Checksum incorrectThe diagnostic function monitors the currency and the checksum of the message.
0xCD9252626PT-CAN, message (parking brake status, 201): missingThe diagnostic function monitors reception of the message.
0xCD9552629PT-CAN, message (light status, 21A): missingThe diagnostic function monitors reception of the message.
0xCD9852632PT-CAN, no message (trailer status, 2E4):The diagnostic function monitors reception of the message.
0xCD9B52635PT-CAN, no message (time/date, 2F8):The diagnostic function monitors reception of the message.
0xCD9D52637PT-CAN, message (vehicle mode, 315): Checksum incorrectThe diagnostic function monitors the currency and the checksum of the message.
0xCD9E52638PT-CAN, message (vehicle mode, 315): missingThe diagnostic function monitors reception of the message.
0xCDA152641PT-CAN, message (power management, charging voltage, 334): missingThe diagnostic function monitors reception of the message.
0xCDA252642PT-CAN, message (soft top, convertible status, 0x27E): missingThe diagnostic function monitors reception of the message.
0xCDA452644PT-CAN, no message (reverse gear status, 3B0):The diagnostic function monitors reception of the message.
0xCDA552645PT-CAN, message (torque request, steering, B1): AFS/STE disabled or steering torque invalidThe diagnostic function monitors the requested torque.
0xCDA652646PT-CAN, message (torque request, steering, B1): checksum wrongThe diagnostic function monitors the currency and the checksum of the message.
0xCDA752647PT-CAN, no message (torque request, steering, B1):The diagnostic function monitors reception of the message.
0xCDA852648PT-CAN, message (torque request, AFS, B9): AFS/STE disabled or steering torque invalidThe diagnostic function monitors the requested torque.
0xCDA952649PT-CAN, message (torque request, AFS, B9): checksum wrongThe diagnostic function monitors the currency and the checksum of the message.
0xCDAA52650PT-CAN, no message (torque request, AFS, B9):The diagnostic function monitors reception of the message.
0xCDAB52651PT-CAN, message (wheel torque request, drive train, front passenger side): Alive checkThe diagnostic function monitors the currency and the checksum of the message.
0xCDAC52652PT-CAN, message (wheel torque request, drive train, front passenger side): Checksum incorrectThe diagnostic function monitors the currency and the checksum of the message.
0xCDAD52653PT-CAN, message (wheel torque request, drive train, front passenger side): missingThe diagnostic function monitors reception of the message.
0xCDB052656PT-CAN, no message (steering wheel angle, C4):The diagnostic function monitors reception of the message.
0xCDB152657PT-CAN communication fault: DPRAM CAN module faultyThe diagnostic function monitors the CAN controller in the DME.P3201Powertrain CAN, DPRAM-CAN Chip Defective
0xCDB252658
0xCDB352659PT-CAN, message (torque request AFS, B9): torque loss too greatThe diagnostic function monitors the requested torque.
0xCDB452660Service (0x5E0, OBD sensor, diagnostic status): missingThe diagnostic function monitors reception of the message.U1169Lost Communication with OBD-Sensor
0xCDB652662PT-CAN, message (torque request, steering, B1): torque loss too greatThe diagnostic function monitors the requested torque.
0xCDB752663PT-CAN, message (fuel pump status, 335): missingThe diagnostic function monitors reception of the message.
0xCDB852664
0xCDB952665
0xCDBA52666
[TBODY] [/TBODY]
Aug 2, 2017
15
2011 e92 335i
I ran MHD scan and it threw this code...
0x29D810712Intake air temperature sensor, plausibility: Intake-air temperature too highThe diagnostic function monitors the intake-air temperature to detect implausibly high figures.P0127Intake Air Temperature Too High
[TBODY] [/TBODY]
Looks like I need to clean my MAF sensor...and I am running Burger Tuning intake
Any other opinion on this?
TomcatSTL
2013 X5 E70
To view all the columns, you'll need to download the PDF as not all have been included due to formatting purposes.
I formatted that PDF to a searchable Excel spreadsheet...
Cheers
  • BMW N55 Diagnostic Fault Codes.xlsx
