Hi All
I am new to this forum, if there is certain etiquette to follow let me know.
I've got a second hand BMW recently and have basically been scammed where the seller said all was good. Once I bought it, and started driving, the car dash came on with a engine management light. The seller has disappeared with my money and scammed me into buying this broken car.
Once a OBD reader was plugged in, it came with the below faults.
There are quite a few codes I don't know what they mean. I hope this group is able to help. I would appreciate if there was any solution any one could point me to.
Should I erase the codes and rescan and see what faults come on, and also while I'm driving at low speeds the engine management light doesn't come on.
CAS Car Access System
ECM Engine Control Module
EPS Electronic Power Steering
JBE Junction Box Electronics
INSTR Instrument Cluster
FZD Function Centre Roof
RLSS Rain Light Solar Sensor
FRM Footwell Module
MOST System Analysis
CAN Communication Analysis
- A0C1 Output Terminal 50
- A0C2 Output Terminal 50, RS
- A0B4 Engine Start, Starter Operation
- 29CD Combustion Misfires Cylinder 1
- 2E19 Firing, Cylinder 2
- 2E18 Firing, Cylinder 1
- 2E1B Firing Cylinder 4
- 2D06 Air Mass System
- 63F5 Reduction Servo Power due to low supply voltage
- A6D0 Control valve in A/C compressor
- A6CF AUC Sensor
- A559 Instrument Cluster power supply has been switched off (closed circuit current cut off relay)
- A670 Fogging Sensor
- DE88 LIN Bus wire fault
- A129 RLS Rain sensor on window not calibrated
FRM Footwell Module
- E598 no message (driving lights)
- E596 no message from Autobeam
