Spec 3+ clutch and aluminum flywheel won't engage after burnout
Title says it all dropped the clutch and did a small burnout and then heard a pop and could not engage into any gears. Have I welded my flywheel and clutch together?
Reactions: colo_evo
That's impressive you were able to do both simultaneously, must have been really abusing the car. The snap you heard was the axle.
Ya I think I was heating the clutch up alot because I kept doing pulls before I got to the stop sign I decided to drop the clutch and then I heard the axle pop. It was also 5 degrees up here in MN turbos we're gobbling up the cold air.
  • Wow
Reactions: d8rknight
